ESP32Cam and Servo Control
benjaraccoon
Re: ESP32Cam and Servo Control
Postby benjaraccoon » Sun Nov 10, 2019 9:44 pm
Hi MadScientist I am a physics student who is doing a project very similar to yours, I have to control 4 servomotors with the ESP32-CAM and also be streaming, do you think this is possible?
Code: Untitled.txt Select all
LBLBLBLB
Postby LBLBLBLB » Mon Dec 16, 2019 12:39 pm
Hi Mad scientist,
I am trying to do like you did and have the servo and cam both work at the same time. Can you explain how you got around sending servo and the cam over wireless at the same time?
Thank you very much
xgarbxgarb
Postby xgarbxgarb » Sun Dec 22, 2019 5:06 pm
Hi Mad scientist,
Thank you very much
Here's how I did a pan and tilt platform with the ESP32-CAM - https://robotzero.one/pan-and-tilt-cont ... esp32-cam/ There might be some helpful code in the tutorial.
LBLBLBLB
Postby LBLBLBLB » Mon Dec 23, 2019 12:28 pm
Hi Mad scientist,
Thank you very much
Thanks - I have seen that one. Just trying to figure out how I can send the servo values from my computer (I have another program that is generating where the servos should move to).
tchalabi
Postby tchalabi » Sat Jun 19, 2021 10:40 pm
Hello MadScientist,
I'm have the same trouble getting the camera and servo to run simultaneously.
Can you provide a code snippet that shows how you solved the timer issue?
Thanks!
Users browsing this forum: Amazon [Bot] and 0 guests
