UART Problem on GPIO 32 / 33
kacie_23
Postby kacie_23 » Mon Jan 20, 2020 12:39 pm
I just tried to implement a GPS communication on GPIO 32/33 TX/RX. (pin 8 and pin 9 on wroom32).
I can see on my oscilloscope that writing on GPIO32 / TX works, indicating that the uart init (UART_NUM_1) have succeded.
I am also getting a lot of data on the input, by looking at the oscilloscope.
But when I try to do this :
	uint8_t *data = (uint8_t *) malloc(RF_RECEIVER_BUF_SIZE);
	int len = uart_read_bytes(UART_Masterport, data, RF_RECEIVER_BUF_SIZE, (timeout < 0 ? ticksToWait : pdMS_TO_TICKS(timeout)));
    	printf("Output %d bytes: %s",len, (const char*)data);
Length is zero, and just garbage from the buffer.
Do I have to configure the GPIO in some way, or will the UART init process do this?
Re: UART Problem on GPIO 32 / 33
Postby Sprite » Tue Jan 21, 2020 9:14 am
Normally the UART init process will do that. Also wrt garbage: if len is 0, the buffer output is undefined (but most likely whatever was in the memory region before malloc() allocated it)
Users browsing this forum: Amazon [Bot] and 2 guests
