which external flash can i use for replacing internal flash
Partokus
Postby Partokus » Sat Feb 01, 2020 1:59 pm
Sorry for english and i am not very good in esp32.
I use ESP-32 WROVER-B 16MB
I want to use micro sd card as main memory and will connect paralelly with internal flash besides CS pin what give me set new flash instead internal. I have yet two questions.
1) What the maximum size of micro sd card can be?
2) I know i must reconfigure EFUSes all pins of SPI Bus and specially CS pin but what i to do else for my porpose?
Re: which external flash can i use for replacing internal flash
Postby Sprite » Sat Feb 01, 2020 4:56 pm
Let me stop you here:
If you mean 'instead of the internal SPI flash', that's not possible, period.
Partokus
Postby Partokus » Mon Feb 03, 2020 11:19 am
thank you for reply :D i just got that idea because i think micro sd card has flash memory and have SPI interface as internal SPI flash memory has... Tell me please why it is not possible?
Postby Sprite » Mon Feb 03, 2020 3:42 pm
Because while both can be accessed over SPI, the higher interface to a SPI flash memory chip (so the commands, bitfields, general way the interface works) is entirely different from the SPI mode of an SD card. The hardware that is used inside the ESP32 to access it is only capable of speaking the protocol of SPI flash chips.
Partokus
Postby Partokus » Fri Feb 07, 2020 1:30 pm
Thank you! Anyway i refused that idea by reason that i don't need sd card for mobile programming esp32 because i got knowledge about OTA programming! esp32 can programming through Wi-Fi it is awesome
PeterR
Postby PeterR » Sat Feb 15, 2020 11:59 pm
Although you could load programs from SD into IRAM and then execute.
I think Sprite is saying that the ESP32 extended memory capabilities (e.g. automatic cached flash execution) cannot be tied to an SD card.
If you're program fits in IRAM then you could load IRAM from SD. If not then maybe you can come up with a manual cache strategy. Latter is a bed of nails though. Adding external FLASH (as an ESP package option) is a lot cheaper than an SD card. Keep in mind that you may struggle to write to internal FLASH whilst your program runs in real time.
Users browsing this forum: PetalBot, Qwantbot and 2 guests
