ESP32 16MB flash module identification on cover
MarekBujko
Postby MarekBujko » Fri Feb 14, 2020 5:30 pm
I noticed that newer ESP32-WROVER-B/IB or ESP32-WROOM-32D modules with 16MB flash have XX0H28 on cover. From "Product Ordering Information" I found that ESP32 with 16MB flash has H28 code in "Manufacturer Part Number". Is that right?
ullixesp
Re: ESP32 16MB flash module identification on cover
Postby ullixesp » Sat Apr 17, 2021 12:49 pm
Looks like you have already identified it?
I just received my order for "ESPRESSIF ESP32-WROOM-32E" with flash of 4, 8, 16 MB flash, and the covers have the imprint of:
XX0H32
XX0H64
XX0H28
respectively.
I haven't tested yet but the imprint at least looks like the flash in MBit with the "1" of "128" dropped.
ullixesp
Postby ullixesp » Thu Apr 22, 2021 2:30 pm
I can now confirm that the chips are 'revision 3' and are indeed 4, 8, 16 MB.
The tests were done with the attached CHIPTEST script. It runs with auto-partitioning under UECIDE https://uecide.org/ When used under Arduino IDE you need to set the partitions manually.
This is part of the outcome for the 16 MB chip:
       partition addr: 0x290000; size: 0xd70000; label: ffat
       FFat File system mounted
       Total space:   13938688
       Free space:    13938688
       FlashChipSize:  16777216    (0x1000000)
       ChipRevision:   3
14 MB free space on FFat :D
kevinx
Postby kevinx » Tue Feb 21, 2023 7:39 pm
Hello, where I can get the CHIPTEST script?
ullixesp
Postby ullixesp » Wed Feb 22, 2023 12:13 pm
here:
CHIPTEST 1.0.zip
(2.11 KiB) Downloaded 810 times
Users browsing this forum: Semrush [Bot], YisouSpider and 8 guests
