wemos d1 r32
esptool says usb not available, output from serial monitor follows:
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5816
entry 0x400806ac
ets Jun 8 2016 00:22:57
any way to recover it?
Thx,
Bill
non stop reboot loop keeps usb locked
Re: non stop reboot loop keeps usb locked
check gpio pins
https://github.com/espressif/esptool/wi ... -Selection
if remove any connected hardware then programming too bad?
If use serial monitor when programming, then serial monitor lock the serial port, and esptool can't connect to this serial port
mikronauts
Thanks. Power cycling the computer just got me running.
check gpio pins
Users browsing this forum: PetalBot, YisouSpider and 1 guest
