esp-idf-tools-setup-2.2 has failed with exit code 1
brp80000
Postby brp80000 » Wed Mar 04, 2020 3:59 pm
I try to setup esp-idf-4.0
Installation has failed with exit code 1
Setup Log 2020-03-04 #006.txt
(40.41 KiB) Downloaded 645 times
krzychb
Contact:
Re: esp-idf-tools-setup-2.2 has failed with exit code 1
Postby krzychb » Wed Mar 04, 2020 4:27 pm
Hi brp80000,
1. Use https://dl.espressif.com/dl/esp-idf-tools-setup-2.3.exe
2. Let the installer download a fresh copy of ESP-IDF
The issue details are covered in https://github.com/espressif/esp-idf/issues/4744
brp80000
Postby brp80000 » Wed Mar 04, 2020 9:59 pm
esp-idf-v4.0 more dont work with eclipse?
krzychb
Contact:
Postby krzychb » Wed Mar 04, 2020 10:45 pm
It does work https://docs.espressif.com/projects/esp ... setup.html
(this information has not been updated in v4.0 docs)
brp80000
Postby brp80000 » Wed Mar 04, 2020 11:12 pm
This does not work again at the first installation step. It seems that manufacturers do not want to sell and maintain their products. Very sad. Two days have already been lost to upgrade from esp-idf-v3. 2. 2 to esp-idf-v4.0
kondalkolipaka
Postby kondalkolipaka » Thu Mar 05, 2020 2:13 pm
We are very sorry for the inconvenience caused.
Looks like the issue is caused by the Eclipse version - Could you make sure you have got the Eclipse 2018-12 CDT and above
https://github.com/espressif/idf-eclips ... requisites
Please provide the eclipse environment information to check further on this. Please copy and paste the entire config information and attach here.
Help > About Eclipse >Installation Details > Configuration
brp80000
Postby brp80000 » Fri Mar 06, 2020 10:20 am
Thank you , installing Eclipse 12-2018 helped. I was able to open my project from v3. 2. 2 But there are problems with include. Files are visible , but errors appear during compilation.
brp80000
Postby brp80000 » Fri Mar 06, 2020 10:58 am
And finally the final chord, after restarting the Eclipse nothing else works. It's probably time to go back to v3. 2. 2. At least through the ass, but everything worked. :lol:
brp80000
Postby brp80000 » Fri Mar 06, 2020 2:50 pm
Stable version 3.2.2 is waiting for me. V4 never again .
Users browsing this forum: Applebot, Baidu [Spider] and 1 guest
