VS Code - Size Analysis
gunar.kroeger
Postby gunar.kroeger » Mon Mar 16, 2020 12:55 pm
This looks nice, but should I change something to get it working?
108KB/20KB doesn't feel right.
"Running was invented in 1612 by Thomas Running when he tried to walk twice at the same time."
Soumesh
Re: VS Code - Size Analysis
Postby Soumesh » Fri May 15, 2020 8:00 am
Could you maybe post the output for
$ python $IDF_PATH/tools/idf_size.py build/{app_name}.map --json
app_name is your app name here
Also please provide your OS, IDF Version, VSCode Version and VSCode Extension Version (can be found in the installed extension page)
gunar.kroeger
Postby gunar.kroeger » Fri May 15, 2020 9:42 pm
I'm on windows 10, IDF 4.0, Extension version 0.2.1, vscode 1.45.0.
This happens to everyone on different PCs with the same big project we are working on.
Trying out different projects gives different results for the maximum DRAM and IRAM available, which makes no sense to me.
I'm compiling for the esp32-pico
Annotation 2020-05-15 183503.png (49.05 KiB) Viewed 10381 times
Soumesh
Postby Soumesh » Tue Jun 16, 2020 12:00 pm
As you can see in the Json Data you've posted ... there are some issue
available_iram: 13439
used_iram: 117633
Which is causing this issue... Will discuss this further with colleagues from IDF and see why this issue is happening?
Roland
Postby Roland » Tue Jun 16, 2020 12:25 pm
Hi gunar.kroeger,
is it possible to share with us your MAP file? Note that it might contain sensitive information if it is a commercial project with closed source. In that case are you able to reproduce the issue with some other project (eg. IDF example)?
Do you get the same values with idf_size.py from the IDF master branch? (can be tested in console and no need to rebuild the project)
The MAP file is parsed by idf_size.py and it is possible that your project contains some unexpected organization of the segments there.
boarchuz
Postby boarchuz » Tue Jun 16, 2020 12:39 pm
Are they not simply showing used/free instead of the expected used/total? The bars should be using the ratio values or used/(used+available) instead.
It would also be great to have the total_size front-and-centre in this view.
Soumesh
Postby Soumesh » Tue Jun 16, 2020 1:41 pm
Correct will fix this behaviour, same can be tracked https://github.com/espressif/vscode-esp ... issues/128
