Java for Esp32
Java for Esp32
Hello everyone, I want programming esp32 with java and I don't know if there is a way to do this, I have made a research but I didn't found anything. If there isn't a such thing, can anyone to point me some references/directions(/examples of portage) to do this. Thank you.
Re: Java for Esp32
If there is java support somewhere, it's likely not to be well-supported... you may want to look into some more mainstream langues that are used more on the ESP32... C, C++ (Arduino), Javascript (NodeMCU) and MicroPython all are options.
Re: Java for Esp32
I don't agree with you, if there is a java support that adds more options, more communities... Now I'm using C, Micropython and I don't have any problem with these language, but I wonder if anyone can point me how to let java supported for esp32 juste like Micropython.
Re: Java for Esp32
No, I mean I do not know of any mainstream Java toolchain for the ESP32. In case I missed one that does exist, it's likely not very big, or else I would have heard about it. Just observing, I have nothing against Java communities Some Googling reveals there is something ( http://developer.microej.com/getting-st ... rover.html ) but it's a commercial SDK.
Re: Java for Esp32
Hi all,
Secure fast Java is available on ESP32 since several years, from the company MicroEJ:
https://developer.microej.com/create-yo ... erkit-v41/
https://developer.microej.com/create-yo ... r-kit-v41/
An old Press Release from their web site announces:
+37Millions devices Powered by MicroEJ, some based on ESP32.
https://www.microej.com/press_release/c ... -standard/
Some images in the next url:
https://developer.microej.com/microej-v ... vironment/
talk about "managed code" (java, javascript, etc.) ==> MicroEJ VEE sounds to be more than just Java?
And sounds like there is complete digital twin: ESP32WROVER Virtual Device, which makes it trivial to start java programming for ESP32.
Hope it helps,
Cheers
Rob
Hope it helps,
Cheers
Rob
Users browsing this forum: No registered users and 101 guests
