Facts:
- esp-idf v4.0
- macOS 10.5.4
Problem:
I want to get time based interrupts (timer / alarms). So I studied this example: https://github.com/espressif/esp-idf/tr ... imer_group
I can compile it and flash it a ESP32-WROVER-V DevKitC board. As soon as I copy the content of the above mentioned example to my own project code, I cannot compile it anymore using
idf.py buildCode: Select all
../main/hello_world_main.c:60:5: error: implicit declaration of function 'timer_spinlock_take' [-Werror=implicit-function-declaration]
timer_spinlock_take(TIMER_GROUP_0);
../main/hello_world_main.c:64:27: error: implicit declaration of function 'timer_group_get_intr_status_in_isr'; did you mean 'timer_group_intr_disable'? [-Werror=implicit-function-declaration]
uint32_t timer_intr = timer_group_get_intr_status_in_isr(TIMER_GROUP_0);
../main/hello_world_main.c:65:36: error: implicit declaration of function 'timer_group_get_counter_value_in_isr'; did you mean 'timer_get_counter_value'? [-Werror=implicit-function-declaration]
uint64_t timer_counter_value = timer_group_get_counter_value_in_isr(TIMER_GROUP_0, timer_idx);
../main/hello_world_main.c:74:22: error: 'TIMER_INTR_T0' undeclared (first use in this function); did you mean 'TIMER_INTR_MAX'?
if (timer_intr & TIMER_INTR_T0) {
TIMER_INTR_MAX
../main/hello_world_main.c:74:22: note: each undeclared identifier is reported only once for each function it appears in
../main/hello_world_main.c:76:9: error: implicit declaration of function 'timer_group_clr_intr_status_in_isr'; did you mean 'timer_group_intr_disable'? [-Werror=implicit-function-declaration]
timer_group_clr_intr_status_in_isr(TIMER_GROUP_0, timer_idx);
../main/hello_world_main.c:78:9: error: implicit declaration of function 'timer_group_set_alarm_value_in_isr'; did you mean 'timer_get_alarm_value'? [-Werror=implicit-function-declaration]
timer_group_set_alarm_value_in_isr(TIMER_GROUP_0, timer_idx, timer_counter_value);
../main/hello_world_main.c:79:29: error: 'TIMER_INTR_T1' undeclared (first use in this function); did you mean 'TIMER_INTR_MAX'?
} else if (timer_intr & TIMER_INTR_T1) {
TIMER_INTR_MAX
../main/hello_world_main.c:87:5: error: implicit declaration of function 'timer_group_enable_alarm_in_isr'; did you mean 'timer_enable_intr'? [-Werror=implicit-function-declaration]
timer_group_enable_alarm_in_isr(TIMER_GROUP_0, timer_idx);
timer_enable_intr
../main/hello_world_main.c:91:5: error: implicit declaration of function 'timer_spinlock_give' [-Werror=implicit-function-declaration]
timer_spinlock_give(TIMER_GROUP_0);
#include <stdio.h>
#include <esp_types.h>
#include <string.h>
#include "sdkconfig.h"
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include <freertos/queue.h>
#include <driver/gpio.h>
#include <esp_system.h>
#include <esp_spi_flash.h>
#include <nvs_flash.h>
#include <driver/timer.h>
#include "mcp23x17.h"
#include "mcp23x17.c"
#include "pinning.h"
