Failed to create MQTT task
nzh912
Postby nzh912 » Fri Apr 10, 2020 3:20 am
E (110796) MQTT_CLIENT: C:/Users/msys32_stable_v3.3.1/home/Admin/esp/esp-idf/components/mqtt/esp-mqtt/mqtt_client.c:482 (esp_mqtt_client_init)
: Memory exhausted
W (110806) MQTT_CLIENT: Client asked to stop, but was not started
E (110816) MQTT_CLIENT: Client was not initialized
i got this error when my esp32 failed to create mqtt task.
Re: Failed to create MQTT task
Postby Sprite » Fri Apr 10, 2020 7:30 am
Okay. What is your question?
nzh912
Postby nzh912 » Fri Apr 10, 2020 1:20 pm
the error showing that memory exhausted when initializing the mqtt client.
How to fix this problem? is there any way i can do to flush the memory or clean the memory.
Postby Sprite » Sat Apr 11, 2020 8:27 am
It means that there is no more free memory. You need to use less memory in the rest of your program.
nzh912
Postby nzh912 » Sat Apr 11, 2020 9:11 am
beside reduce the memory usage of my program, is there if i use external SRAM can increase the memory size?
Now i am developing the program using ESP32-WROOM-32D (4MB).
Postby Sprite » Sun Apr 12, 2020 8:41 am
You could switch to a module with PSRAM, indeed.
nzh912
Postby nzh912 » Sun Apr 12, 2020 10:49 am
thank you for the info.
Beside that, it seem like the wifi task took a lot of memory, is there a method i can flush out/clear the wifi memory ?
Postby Sprite » Mon Apr 13, 2020 6:32 am
I think you can set the amount of tx/rx buffers in menuconfig. This will impact your WiFi speeds a bit, though; not sure if that's very relevant if you only send/receive mqtt messages.
Users browsing this forum: Baidu [Spider], Bing [Bot], Semrush [Bot] and 9 guests
