Many of my questions remain unanswered, request you to please reply as I am in the middle of development of my project.
I need to update flash with the latest app.bin developed by me for which I was trying OTA example given by you and followed the instruction as described in below link:
https://github.com/espressif/esp-idf/tr ... system/ota
Also, below command(as mentioned in the above link) was not working
openssl req -x509 -newkey rsa:2048 -keyout ca_key.pem -out ca_cert.pem -days 365
Generating a 2048 bit RSA private key
(stuck here)
I tried below command for generating the pem file, which generated the file but the overall code is not working:
openssl req -new -newkey rsa:2048 -days 365 -nodes -x509 -keyout ca_key.pem -out ca_cert.pem
After generating the certificates, running the server on terminal and built the ota code after changing the configurations:
Error received in the code:
I (8344) event: sta ip: 192.168.1.2, mask: 255.255.255.0, gw: 192.168.1.1
I (8344) native_ota_example: Connect to Wifi ! Start to Connect to Server....
E (26604) esp-tls: Failed to connnect to host (errno 113)
E (26604) esp-tls: Failed to open new connection
E (26604) TRANS_SSL: Failed to open a new connection
E (26604) HTTP_CLIENT: Connection failed, sock < 0
E (26614) native_ota_example: Failed to open HTTP connection: ESP_ERR_HTTP_CONNECT
E (26624) native_ota_example: Exiting task due to fatal error...
Please help to resolve the issue on urgent basis.
What is the correct way of operating OTA in esp32??
Ritu
OTA Example not running as described
Re: OTA Example not running as described
ECONNABORTED = 113. No really time to start worrying about the cert yet. You don't seem to be finding the server or the server isn't listening on the port.
John A
John A
I too have the same issue when performing OTA please guide what to do further?
Users browsing this forum: PerplexityBot, Qwantbot and 0 guests
