I have a problem regarding ESP-ADF v3.3.1
Could you please give me hints why it is not working?Note: You are using Python 3.8.2. Python 3 support is new, please report any problems you encounter. Search for 'Setting the Python Interpreter' in the ESP-IDF docs if you want to use Python 2.7.
Checking Python dependencies...
Python requirements from C:\esp-adf\esp-idf\requirements.txt are satisfied.
Running cmake in directory C:\esp-adf\examples\get-started\play_mp3\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 --warn-uninitialized C:\esp-adf\examples\get-started\play_mp3"...
Warn about uninitialized values.
CMake Error at CMakeLists.txt:5 (include):
include could not find load file:
"C:\esp-adf"/CMakeLists.txt
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.26.0.windows.1")
-- IDF_TARGET not set, using default target: esp32
-- Building for target esp32
-- ccache will be used for faster builds
-- The C compiler identification is GNU 5.2.0
-- The CXX compiler identification is GNU 5.2.0
-- The ASM compiler identification is GNU
-- Found assembler: C:/Users/abdul/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a5-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/abdul/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a5-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/abdul/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a5-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/Users/abdul/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a5-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe
-- Check for working CXX compiler: C:/Users/abdul/.espressif/tools/xtensa-esp32-elf/1.22.0-80-g6c4433a5-5.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Error at C:/esp-adf/esp-idf/tools/cmake/component_utils.cmake:20 (message):
Required component audio_sal is not found in any of the provided
COMPONENT_DIRS
C:/esp-adf/esp-idf/tools/cmake/scripts/expand_requirements.cmake:95 (find_component_path)
C:/esp-adf/esp-idf/tools/cmake/scripts/expand_requirements.cmake:114 (expand_component_requirements)
C:/esp-adf/esp-idf/tools/cmake/scripts/expand_requirements.cmake:217 (expand_component_requirements)
Kind regards,
Karim
