I build a wearable based on esp32 witch connects to an iOS app. It would be great if my customers could see the current battery level in the default iOS widget. To do so, you have to implement the custom at-command „HFP Command AT+XAPL“.
In Detail it is described here: 13.1 page 66:
https://developer.apple.com/accessories ... pdf#page66
Did anyone implement this? Or does this only works for bluetoooth and not Bluetooth LE?
Thanks a lot
Esp32 in iOS battery widget use HFP Command AT+XAPL
schluesselmeister
Re: Esp32 in iOS battery widget use HFP Command AT+XAPL
Did you get any answer about this? I would like to do the same with BLE.
Cheers.
Cheers.
sudhirmetaliya
I have implemented AT+XAPL command. But for this you have to make changes to the ESP32 IDF framework and add functions implementing APPLE command. There is no direct function available that can be used to send custom AT commands.
can you please share the changes @sudhirmetaliya
sudhirmetaliya
I have attached the changes.txt file, follow the instructions mentioned in it to make the respective changes in ESP-IDF. All the details like dir, file name, line number and changes to be made are mentioned in the file.
- changes.txt
- (3.7 KiB) Downloaded 641 times
Hello, I'm new in develop ESP32. I do this changes like in your instruction, but have errorsI have attached the changes.txt file, follow the instructions mentioned in it to make the respective changes in ESP-IDF. All the details like dir, file name, line number and changes to be made are mentioned in the file.
esp/esp-idf/components/bt/host/bluedroid/api/esp_hf_client_api.c:339:16:error: 'BTC_HF_CLIENT_SEND_APPLE_EVT' undeclared (first use in this function); did you mean 'BTC_HF_CLIENT_SEND_NREC_EVT'?
msg.act = BTC_HF_CLIENT_SEND_APPLE_EVT;
esp/esp-idf/components/bt/host/bluedroid/api/esp_hf_client_api.c:358:16: error: 'BTC_HF_CLIENT_SEND_BATT_EVT' undeclared (first use in this function); did you mean 'BTC_HF_CLIENT_SEND_NREC_EVT'?
msg.act = BTC_HF_CLIENT_SEND_BATT_EVT;
/esp/esp-idf/components/bt/host/bluedroid/api/esp_hf_client_api.c:362:9: error: 'btc_hf_client_args_t' {aka 'union <anonymous>'} has no member named 'apple_batt'
arg.apple_batt.val = val;
Does this file contain all the changes?
missing BTC_HF_CLIENT_SEND_APPLE_EVT definition
and BTC_HF_CLIENT_SEND_BATT_EVT
In newer IDF 5.0 components updated and have the same examples with apple specific commands, but it doesn't work on iPhone specifically. and it works on android OS/
Can you help me?
Maybe because IDF 5.0 does not stable release.
Users browsing this forum: Google [Bot], Semrush [Bot] and 2 guests
