Esp Now distance.
jrubic
Esp Now distance.
Postby jrubic » Sat May 09, 2020 10:09 am
I am developing a project that communicates several sensors with a Gateway through Esp_Now. All teams are Esp32. There is no connection to the router wifi. Everything works well when I have the equipment nearby and in sight, but if I pass them to different rooms even if they are less than 10 meters away, the signal does not arrive. Can anyone help me on this?
Thanks in advance.
Jorge.
username
Re: Esp Now distance.
Postby username » Sun May 10, 2020 12:11 pm
I don't know if there is another solution in software to help. I do remember seeing a way to change the output power. But I don't know if by default its set to the highest level.
I would also look into using the ESP32 module with the U.FL (IPEX) CONNECTOR on it.
https://www.gridconnect.com/products/es ... -connector
