ESP32 core 1 panic'ed when EEPROM and timer interrupt used together
pwdandekar
Postby pwdandekar » Tue Jan 14, 2020 6:36 am
I am reading an analog input in timer ISR, 100 times per second. If I write this 12-bit value in EEPROM (only once per second), I am getting following error:
Guru Meditation Error: Core 1 panic'ed (Cache disabled but cached memory region accessed)
Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x400e9408: bad00bad bad00bad bad00bad
I am using Arduino IDE and board name selection is NODE-32S and flash frequency is 80 MHz.
If I comment out //EEPROM.commit(); then program runs well. Please help. Thanks in advance.
#include <EEPROM.h>
const int analogpin = 36; // feed here 0 to 3.3V analog signal.
int analog_count = 0; // variable to store ADC count
int address = 0;// EEPROM Address
#define eeprom_size 2 // Size of EEPROM 2 bytes to store int variable
hw_timer_t * timer = NULL;// define a pointer which can point to our timer
portMUX_TYPE timerMux = portMUX_INITIALIZER_UNLOCKED;// to synv loop and isr
void IRAM_ATTR onTimer(void);
void setup()
Serial.begin(115200);
while(!EEPROM.begin(eeprom_size))
Serial.println("Failed to initialise EEPROM");
// setup timer and timer interrupts
timer = timerBegin(0, 80, true);
timerAttachInterrupt(timer, &onTimer, true);
timerAlarmWrite(timer, 10000, true);// 10000 microseconds or every 10 ms this interrupt will be generated.
timerAlarmEnable(timer);
void loop()
EEPROM.writeInt(address,analog_count);
//EEPROM.commit(); // If this line is un-commented then program crashes.
Serial.print("EPROM write data = ");
Serial.println(analog_count);
delay(1000);
void IRAM_ATTR onTimer()
portENTER_CRITICAL_ISR(&timerMux);
analog_count = analogRead(analogpin);
portEXIT_CRITICAL_ISR(&timerMux);
Colargol
Re: ESP32 core 1 panic'ed when EEPROM and timer interrupt used together
Postby Colargol » Sat May 09, 2020 5:16 pm
I have the same problem as you with EEPROM.commit() with the use of the interrupt timer.
I have tried several solutions read on the internet, but nothing corrects this problem.
Did you find a solution ?
Thank you
shrimantpatel
Postby shrimantpatel » Sat May 30, 2020 7:56 pm
On the same boat....but have a temp workaround:
detachInterrupt(interruptPin);
EPROM.put.....
EPROM.commit();
delay(2500);
attachInterrupt(interruptPin, ISRroutine, RISING);
shrimantpatel
Postby shrimantpatel » Sun May 31, 2020 1:25 am
So here is what finally that worked for me:
1. Find the amount of time it takes to finish all the activities on the onTimer() routine using millis().
2.Just before EPROM.commit()
  • stop the timer(hw_timer_disarm(void))
  • Optional: detach interrupt
  • Depending on what you found in step 1 above put a delay (n) , so if you found that control spends 10ms in the timer routine then put a Delay(10).
3.execute EPROM.commit() after the above steps.
4. Arm/Start the timer , in case you detached the interrupt attach it back.
emhatek
Postby emhatek » Tue Sep 20, 2022 5:05 am
Hi SrimanPatel,
thanks for your valuable advice, it's work for me.
nedjmo
Postby nedjmo » Sun Dec 25, 2022 12:48 pm
i dont understand ..how can used EEPROM and timer interrupt used together
Users browsing this forum: ChatGPT-User, Semrush [Bot] and 3 guests
