I would like to know if there is documentation on how to connect an ESP32 (FreeRTOS) with and Android device. I guess it should be similar to what ESPNow does to share the Wifi settings from the Android device to the ESP32.
Thanks! Federico
ESP-NOW between ESP32 and Android Device
batmasterson
Re: ESP-NOW between ESP32 and Android Device
I'm looking into something similar - it's likely that if ESP-NOW to Android is possible, it will cover my needs.
That said, from what I've tried/read on ESPNOW so far, it looks like you're going to run into issues trying to use ESP-NOW for anything other than espressif devices. Right now, I'm trying to see if using STAtion mode set for ESP-NOW communication and AccessPoint mode set for Android commuincation would work.
Reference:
https://hackaday.io/project/161896-linux-espnow
Reference:
batmasterson
I got ESP-NOW in STA mode and Android talking to ESP32 AP. I haven't tried anything significant, yet, but I can say that ESP-NOW will transmit and receive even with the device set in APSTA dual mode and launching an open (unsecured) AP.
wkoks_or_UCCMM
Hi sir, would you be as kind as to share the code you come up with? Thank you in advance.I got ESP-NOW in STA mode and Android talking to ESP32 AP. I haven't tried anything significant, yet, but I can say that ESP-NOW will transmit and receive even with the device set in APSTA dual mode and launching an open (unsecured) AP.
