--- idf_monitor on /dev/ttyUSB0 115200 ---
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:4
load:0x3fff0034,len:6948
load:0x40078000,len:14368
load:0x40080400,len:3980
entry 0x4008067c
I (29) boot: ESP-IDF v4.3-dev-472-gcf056a7d0-dirty 2nd stage bootloader
I (29) boot: compile time 18:42:11
I (30) boot: chip revision: 1
I (34) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (41) boot.esp32: SPI Speed : 40MHz
I (46) boot.esp32: SPI Mode : DIO
I (50) boot.esp32: SPI Flash Size : 16MB
I (55) boot: Enabling RNG early entropy source...
I (60) boot: Partition Table:
I (64) boot: ## Label Usage Type ST Offset Length
I (71) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (78) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (86) boot: 2 factory factory app 00 00 00010000 00100000
I (93) boot: End of partition table
I (98) boot_comm: chip revision: 1, min. application chip revision: 0
I (105) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1e750 (124752) map
I (161) esp_image: segment 1: paddr=0x0002e778 vaddr=0x3ffb0000 size=0x018a0 ( 6304) load
I (164) esp_image: segment 2: paddr=0x00030020 vaddr=0x400d0020 size=0x9288c (600204) map
0x400d0020: _stext at ??:?
I (394) esp_image: segment 3: paddr=0x000c28b4 vaddr=0x3ffb18a0 size=0x021bc ( 8636) load
I (398) esp_image: segment 4: paddr=0x000c4a78 vaddr=0x40080000 size=0x00400 ( 1024) load
0x40080000: _WindowOverflow4 at /home/pablo/esp/esp-idf/components/freertos/xtensa/xtensa_vectors.S:1730
I (401) esp_image: segment 5: paddr=0x000c4e80 vaddr=0x40080400 size=0x15c64 ( 89188) load
I (460) boot: Loaded app from partition at offset 0x10000
I (460) boot: Disabling RNG early entropy source...
I (472) cpu_start: Pro cpu up.
I (472) cpu_start: Starting app cpu, entry point is 0x400810d8
0x400810d8: call_start_cpu1 at /home/pablo/esp/esp-idf/components/esp_system/port/cpu_start.c:109
I (0) cpu_start: App cpu up.
I (488) cpu_start: Pro cpu start user code
I (488) cpu_start: Application information:
I (488) cpu_start: Project name: mqtt_tcp
I (493) cpu_start: App version: 1
I (498) cpu_start: Compile time: Jul 21 2020 18:42:16
I (504) cpu_start: ELF file SHA256: 437d79a2e3d57245...
I (510) cpu_start: ESP-IDF: v4.3-dev-472-gcf056a7d0-dirty
I (517) heap_init: Initializing. RAM available for dynamic allocation:
I (524) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (530) heap_init: At 3FFB94F0 len 00026B10 (154 KiB): DRAM
I (536) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (542) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (549) heap_init: At 40096064 len 00009F9C (39 KiB): IRAM
I (556) spi_flash: detected chip: gd
I (559) spi_flash: flash io: dio
I (564) cpu_start: Starting scheduler on PRO CPU.
I (574) MQTT_EXAMPLE: [APP] Startup..
I (574) MQTT_EXAMPLE: [APP] Free memory: 272276 bytes
I (584) MQTT_EXAMPLE: [APP] IDF version: v4.3-dev-472-gcf056a7d0-dirty
I (654) wifi:wifi driver task: 3ffc1b28, prio:23, stack:6656, core=0
I (654) system_api: Base MAC address is not set
I (654) system_api: read default base MAC address from EFUSE
I (674) wifi:wifi firmware version: bbe4b67
I (684) wifi:wifi certification version: v7.0
I (684) wifi:config NVS flash: enabled
I (684) wifi:config nano formating: disabled
I (684) wifi:Init data frame dynamic rx buffer num: 32
I (684) wifi:Init management frame dynamic rx buffer num: 32
I (694) wifi:Init management short buffer num: 32
I (694) wifi:Init dynamic tx buffer num: 32
I (704) wifi:Init static rx buffer size: 1600
I (704) wifi:Init static rx buffer num: 10
I (714) wifi:Init dynamic rx buffer num: 32
I (714) example_connect: Connecting to Nettra...
I (814) phy: phy_version: 4182, f1ba940, Jun 4 2020, 19:40:07, 0, 0
I (814) wifi:mode : sta (4c:11:ae:b6:d8:9c)
I (814) example_connect: Waiting for IP(s)
I (2144) wifi:new:<11,0>, old:<1,0>, ap:<255,255>, sta:<11,0>, prof:1
I (2944) wifi:state: init -> auth (b0)
I (2954) wifi:state: auth -> assoc (0)
I (2994) wifi:state: assoc -> run (10)
I (3094) wifi:connected with Nettra, aid = 3, channel 11, BW20, bssid = 68:ff:7b:4a:96:2b
I (3094) wifi:security: WPA2-PSK, phy: bgn, rssi: -19
I (3094) wifi:pm start, type: 1
I (3124) wifi:AP's beacon interval = 102400 us, DTIM period = 1
I (4644) example_connect: Got IPv6 event: Interface "example_connect: sta" address: fe80:0000:0000:0000:4e11:aeff:feb6:d89c, type: ESP_IP6_ADDR_IS_LINK_LOCAL
I (5644) esp_netif_handlers: example_connect: sta ip: 192.168.86.238, mask: 255.255.255.0, gw: 192.168.86.1
I (5644) example_connect: Got IPv4 event: Interface "example_connect: sta" address: 192.168.86.238
I (5654) example_connect: Connected to example_connect: sta
I (5664) example_connect: - IPv4 address: 192.168.86.238
I (5664) example_connect: - IPv6 address: fe80:0000:0000:0000:4e11:aeff:feb6:d89c, type: ESP_IP6_ADDR_IS_LINK_LOCAL
I (5684) MQTT_EXAMPLE: Other event id:7
I (6404) MQTT_EXAMPLE: MQTT_EVENT_CONNECTED
I (6404) MQTT_EXAMPLE: sent publish successful, msg_id=31011
I (6414) MQTT_EXAMPLE: sent subscribe successful, msg_id=23520
I (6414) MQTT_EXAMPLE: sent subscribe successful, msg_id=59832
I (6414) MQTT_EXAMPLE: sent unsubscribe successful, msg_id=19587
E (6604) MQTT_CLIENT: mqtt_message_receive: received a message with an invalid header=0x42
E (6604) MQTT_CLIENT: mqtt_process_receive: mqtt_message_receive() returned -1
I (6614) MQTT_EXAMPLE: MQTT_EVENT_DISCONNECTED
I (16624) MQTT_EXAMPLE: Other event id:7
I (17054) MQTT_EXAMPLE: MQTT_EVENT_CONNECTED
I (17054) MQTT_EXAMPLE: sent publish successful, msg_id=52630
I (17054) MQTT_EXAMPLE: sent subscribe successful, msg_id=38013
I (17064) MQTT_EXAMPLE: sent subscribe successful, msg_id=56284
I (17064) MQTT_EXAMPLE: sent unsubscribe successful, msg_id=2195
E (17254) MQTT_CLIENT: mqtt_message_receive: received a message with an invalid header=0x42
E (17254) MQTT_CLIENT: mqtt_process_receive: mqtt_message_receive() returned -1
I (17264) MQTT_EXAMPLE: MQTT_EVENT_DISCONNECTED
I (32264) MQTT_EXAMPLE: Other event id:7
