can't run the original demo on ESP32-S2-Kaluga-1 DK
jimmywong2003
Contact:
Postby jimmywong2003 » Sat Aug 15, 2020 3:27 pm
Hi ESP32 guy,
Recently, I bought the ESP32-S2-Kaluga-1 DK board v1.3 version.
I clone the version of https://github.com/espressif/esp-idf.
e.g. d:\esp32\esp-idf
Also,
I clone the S2-Kaluga DK from https://github.com/espressif/esp-dev-kits
e.g. d:\esp32\esp-32\
Point 1:
First, if I install the https://dl.espressif.com/dl/esp-idf-tools-setup-2.3.exe for windows,
but I found that its idf.py doesn't support "set-target esp32s2".
Thus, I can't program (bootloader) on the dk board if just using the idf.py.
Because it can't detect the target board (idf.py -p com26)... error code : timeout
It is better to mention the minimum requirement tools if working for ESP32-S2-Kaluga-1 DK board v1.3.
Point 2:
I try to use the D:\esp32\esp-idf\install.bat to install the tools.
Suggestion (this install.bat can't let the user to specify the tool path).
The default is C:\Users\XXX\.espressif path.
Point 3:
I use the example LCD/Camera from (https://github.com/espressif/esp-dev-kits).
I can't find another release tag on this github. Can you give us the release zip package on particular HW version?
The factory binary file
D:\esp32\esp32-s2\esp32-s2-kaluga-1\examples\factory
it doesn't contain any readme file to specify how to use them (such as address).
Point 4:
I modified the sdkconfig file inside the LCD.
# Example Configuration
CONFIG_LCD_PAD_ESP32_S2_KALUGA_V1_3=y
# CONFIG_LCD_PAD_ESP32_S2_KALUGA_V1_2 is not set
# CONFIG_LCD_PAD_ESP32_S2_KALUGA_V1_1 is not set
CONFIG_LCD_ST7789=y
# CONFIG_LCD_ILI9341 is not set
# end of Example Configuration
but I can't see any jpg on the screen.
I would like to get the working package such as release tag to run on the ESP32-S2-Kaluga-1 DK board v1.3.
Thanks.
Jimmy
meltdown03
Re: can't run the original demo on ESP32-S2-Kaluga-1 DK
Postby meltdown03 » Thu Aug 20, 2020 12:11 am
Where did you purchase the v1.3 Kaluga if I may ask?
jimmywong2003
Contact:
Postby jimmywong2003 » Thu Aug 20, 2020 2:10 pm
订单号: 1159666787956469136
I bought from taobao (official espressif retail).
https://item.taobao.com/item.htm?spm=a1 ... p951qbfcfe
jimmywong2003
Contact:
Postby jimmywong2003 » Thu Aug 20, 2020 11:59 pm
Can you give me the official working repo or package to run on such HW version of the DK board?
Jimmy
ESP_czw
Postby ESP_czw » Tue Aug 25, 2020 7:24 am
please choose master branch
jimmywong2003
Contact:
Postby jimmywong2003 » Sun Sep 06, 2020 7:43 am
git status
I have used the master branch. The problem is still there.
D:\esp32\esp32-s2\esp-dev-kits (master -> origin)
λ git pull
Already up to date.
λ git status
On branch master
Your branch is up to date with 'origin/master'.
Would I get the tag release to work on the DK board?
git status
ESP_czw
Postby ESP_czw » Mon Sep 07, 2020 3:27 am
The branch of IDF selects master,Because IDF's master (more than 4.2 ) supports ESP32S2
ESP_czw
Postby ESP_czw » Mon Sep 07, 2020 9:03 am
1. IDF checkout master
2.
rm -rf build
and
set-target esp32s2
Users browsing this forum: Baidu [Spider], DuckDuckGo [Bot], Semrush [Bot] and 1 guest
