Problem with update esp-idf.
Re: Problem with update esp-idf.
Hi Palonso,
yes, your PATH seems to be fine.
What is the output of `esp32ulp-elf-as --version`? Am I assuming correctly that your system is Linux?
Hi Roland,
Yes, I'm running Linux (Ubuntu 18.04)
here is the output to the ulp-elf version:
Here I translated the message, since I have it in spanish my computer:
Regards,
P
$ esp32ulp-elf-as --version
Ensamblador (GNU Binutils) 2.28.51-esp-20191205 de GNU
Copyright (C) 2017 Free Software Foundation, Inc.
Este programa es software libre; se puede redistribuir bajo los términos de
la Licencia Pública General de GNU versión 3 o posterior.
Este programa no tiene ninguna garantía.
Este ensamblador se configuró para un objetivo «esp32ulp-elf».
GNU Assembler (GNU Binutils) 2.28.51-eng-20191205
This program is free software; may be redistributed under the terms of
the GNU General Public License version 3 or later.
This program has no guarantee.
This assembler was configured for an "esp32ulp-elf" target.
P
Hi Palonso,
Thank you for patience and help narrowing down the issue. This is something new I never faced before.
Could you please try to replace line no. 29 in components/ulp/component_ulp_common.mk:
with this one:
Does this solve your issue?
ULP_AS_VER := $(shell $(ULP_AS) --version | sed -E -n 's|GNU assembler \(GNU Binutils\) ([a-z0-9\.-]+)|\1|gp')
ULP_AS_VER := $(shell $(ULP_AS) --version | sed -E -n 's/.+ \(GNU Binutils\) ([a-z0-9\.-]+)( .*)?/\1/gp')
Hi Roland,
This somehow solved the problem. here is the log from compiling with make:
but when I use idf.py here is the result:
Python requirements from /home/pablo/esp/esp-idf/requirements.txt are satisfied.
GENCONFIG
Loading defaults file /home/pablo/esp/ulp/sdkconfig.defaults...
Building ULP app ulp_main
ULP assembler version: 2.28.51-esp-20191205
Project is not inside a git repository, or git repository has no commits
will not use 'git describe' to determine PROJECT_VER.
App "ulp-example" version: 1
AR build/lwip/liblwip.a
CPP main/ulp/pulse_cnt.S
ULP_AS build/main/pulse_cnt.ulp.o
CPP main/ulp/wake_up.S
ULP_AS build/main/wake_up.ulp.o
CPP build/main/ulp_main.common.ld
ULP_LD build/main/ulp_main.elf
ULP_MAPGEN build/main/ulp_main.sym
ULP_BIN build/main/ulp_main.bin
CC build/main/ulp_example_main.o
EMBED build/main/ulp_main.bin.bin.o
AR build/main/libmain.a
[591/962] Performing configure step for 'ulp_main'
-- The ASM compiler identification is GNU
-- Found assembler: /home/pablo/.espressif/tools/esp32ulp-elf/2.28.51-esp-20191205/esp32ulp-elf-binutils/bin/esp32ulp-elf-as
-- The C compiler identification is GNU 8.2.0
-- Check for working C compiler: /home/pablo/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
-- Check for working C compiler: /home/pablo/.espressif/tools/xtensa-esp32-elf/esp-2020r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Building ULP app ulp_main
-- ULP assembler version:
CMake Warning at CMakeLists.txt:33 (message):
WARNING: ULP assembler version is not supported. Expected to see version:
2.28.51-esp-20191205. Please check ESP-IDF ULP setup instructions and
update the toolchain, or proceed at your own risk.
Hi Palonso,
for fixing idf.py, please try to replace line 16 of components/ulp/cmake/CMakeLists.txt
with this one:
string(REGEX MATCH "GNU assembler \\(GNU Binutils\\) (${version_pattern})" as_version ${as_output})
string(REGEX MATCH "\\(GNU Binutils\\) (${version_pattern})" as_version ${as_output})
Hi, Roland
Perfect now it seems to be working fine in both ways. Here is the log for the idf.py build:
should this be pull-requested to the esp-idf repo? or this was a particular error so I should "fix it" everytime I update the IDF?
regards,
P
[587/962] Performing configure step for 'ulp_main'
-- ULP assembler version: 2.28.51-esp-20191205
-- Configuring done
-- Generating done
-- Build files have been written to: /home/pablo/esp/ulp/build/esp-idf/main/ulp_main
regards,
P
Hi Palonso,
thank you very much for your help. These fixes will be included in all supported releases of ESP-IDF. I cannot tell you when that will happen. Until then you have to fix it for after every IDF update (if your fixes are discarded).
For future reference, commit edd7c1a2eef6c9ae61c026765fce66db63c08140 fixes this issue and will be available in latest master the next time ESP-IDF is updated on Github. The fix will be backported to release branches.
Users browsing this forum: Bytespider, PerplexityBot, Qwantbot, Semrush [Bot] and 1 guest
