***ERROR*** A stack overflow in task Tmr Svc has been detected
What I have is this error only "BT_HCI: command_timed_out hci layer timeout waiting for response to a command. opcode: 0x200c"Of course i am assuming you are getting this error:Code: Select all
I don't think is a solution because, between the end of the scan and the restart there some operations. Anyway I tried adding 2ms delay before the restart and this message appears.In that case maybe try to find when it is happening and try to add small delay before bt command that is causing it.
Users browsing this forum: Bing [Bot], Bytespider, Qwantbot and 0 guests
