I want to change the baudrate of the make monitor for esp32, but after I change it in the make menuconfig and then make flash and monitor the output I only see a bunch of scrambled characters. I tried many other baudrate as well, but only the default 115200bps will print out readable characters. Could anyone help me on this please?
This is the config I have changed:
and this is the make monitor output:
Thank you very much
Changing baudrate of make monitor on esp32
Re: Changing baudrate of make monitor on esp32
This only changes the baud rate on the PC side. You also need to change the baud rate accordingly on the ESP32 side.
2 things:
1) bootloader logs always are printed with 115200, so you will see garbage with different baudrate
2) you can use make monitor ESPBAUD=__baud__ command to change monitor baud rate, try it please
2 things:
1 is correct, but 2 will only (again) change the PC baud rate. A correct answer is that you can configure it via menuconfig: Component config -> Common ESP-related -> UART console baud rate. Note you need to select 'Custom UART' under 'Channel for console output' before you can configure that.
Users browsing this forum: Google [Bot], Qwantbot and 5 guests
