EEPROM
PeWosT
EEPROM
Postby PeWosT » Sun Mar 19, 2017 4:38 pm
Hi, I want to save the ssid and the password of the network. There is a partition that I can use like the EEPROM of arduino? Or I have to use an external flash to save it?
Thanks in advance
krzychb
Contact:
Re: EEPROM
Postby krzychb » Sun Mar 19, 2017 4:52 pm
Hi PeWosT,
Check NVS (Non-Volatile Storage) https://github.com/espressif/esp-idf/tr ... s_rw_value
PeWosT
Re: EEPROM
Postby PeWosT » Sun Mar 19, 2017 6:16 pm
Hi krzychb, thank you for your response. Is it compatible with arduino IDE?
krzychb
Contact:
Re: EEPROM
Postby krzychb » Sun Mar 19, 2017 7:34 pm
@PeWosT,
Sorry, I did not notice you have been posting in ESP32 Arduino forum.
In Arduino, NVS is implemented with Preferences library.
The library includes an example that shows how to save / read an integer counter.
As you like to save strings, then adopt this example using putString / getString methods (instead of putUInt / getUInt as in example).
Krzysztof
PeWosT
Re: EEPROM
Postby PeWosT » Mon Mar 20, 2017 11:04 am
Thank you again @krzychb, I am going to try
Users browsing this forum: Semrush [Bot] and 1 guest
