Our first video is an introductory / quick start for vs code extension, and will keep releasing new one's based on user reactions and suggestions
You can also submit suggestion forms for future videos
There is actually no connection between VScode recognizing includes and IDF compiling properly.I agree
" The whole process is not even similar to what is in the video. As others, I could also almost install it.
My problem is with the included header files not being recognized (#include errors detected. Please update your includePath.)
task_t coffeeTask()
while(atWork){
coffeeDrink(mug);
} else {
vTaskDelete(NULL);
}Code: Select all
> Executing task: cmake -G Ninja .. <
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.31.1.windows.1")
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- The ASM compiler identification is GNU
-- Found assembler: C:/Users/Lukas/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/Lukas/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
CMake Error at C:/Users/Lukas/.espressif/tools/cmake/3.16.4/share/cmake-3.16/Modules/CMakeTestCCompiler.cmake:44 (try_compile):
Failed to open
C:/Users/Lukas/Desktop/Programming/ESP-IDF/test_programs/hello_world/build/CMakeFiles/CMakeTmp/CMakeLists.txt
Permission denied
C:/Users/Lukas/Desktop/Programming/ESP-IDF/esp-idf/tools/cmake/project.cmake:307 (__project)
CMakeLists.txt:6 (project)
-- Check for working C compiler: C:/Users/Lukas/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe -- broken
CMake Error at C:/Users/Lukas/.espressif/tools/cmake/3.16.4/share/cmake-3.16/Modules/CMakeTestCCompiler.cmake:60 (message):
The C compiler
"C:/Users/Lukas/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe"
is not able to compile a simple test program.
It fails with the following output:
CMake will not be able to correctly generate this project.
See also "C:/Users/Lukas/Desktop/Programming/ESP-IDF/test_programs/hello_world/build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/Lukas/Desktop/Programming/ESP-IDF/test_programs/hello_world/build/CMakeFiles/CMakeError.log".
The terminal process "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe -Command cmake -G Ninja .." terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
