S3 USB Support?
askpatrickw
S3 USB Support?
Postby askpatrickw » Fri Jan 08, 2021 8:24 pm
I do not see "USB OTG interface" listed on the S3 description on the SOC page.
https://www.espressif.com/en/products/socs/
Is this just an omission in these early docs or will it really not be supported?
Thanks!
sebasdt
Re: S3 USB Support?
Postby sebasdt » Fri Jan 08, 2021 9:01 pm
hey dude!
I have looked a bit further into this and found this:
https://www.cnx-software.com/2020/12/20 ... 266-price/
searched with: ESP32-C3 Series USB support
On that picture it says it would support USB BUT, when I looked in the datasheet: https://www.espressif.com/sites/default ... eet_en.pdf
I didn't find any info about USB so the way I see it. It probably DOESN'T support "USB OTG interface"
I'm not an expert in this just another hobbyist doing it for the fun.
Re: S3 USB Support?
Postby Sprite » Sat Jan 09, 2021 5:04 am
As far as I know, the S3 will have USB OTG support (both low-speed and high-speed, same as the -S2). Not sure why the datasheet doesn't have it, it may be out of date.
savage
Re: S3 USB Support?
Postby savage » Mon Jan 11, 2021 6:01 pm
The ESP32-S3 and ESP32-C3 are different products, so USB not being listed in the C3 datasheet does not say anything about the S3.
I do not yet see any ESP32-S3 datasheet, but the graphic on the Espressif press release does show USB OTG under the peripherals.
Re: S3 USB Support?
Postby Sprite » Tue Jan 12, 2021 2:25 am
For completion: there is no USB OTG on the -C3. There may or may not be some other (more limited) USB functionality, but that depends on if we can make it work in silicon.
Users browsing this forum: PetalBot and 3 guests
