Compiler thinks I'm giving an int to the CAN_GENERAL_CONFIG_DEFAULT macro
jrveale
Postby jrveale » Mon Jan 18, 2021 10:36 am
I've used CAN in the ESP-IDF succesfully and am currently porting my CAN tester program for use in the ESP32 Arduino environment.
I'm having issues with the CAN_GENERAL_CONFIG_DEFAULT() macro that don't make any sense to me. See the below function (which simply wraps up a default can_driver_install().
esp_err_t InstallCAN(gpio_num_t canTxPin, gpio_num_t canRxPin, can_mode_t canMode)
  // Initialise config structures using macro inits
  can_general_config_t gConfig = CAN_GENERAL_CONFIG_DEFAULT(canTxPin, canRxPin, canMode);
  can_timing_config_t tConfig = CAN_TIMING_CONFIG_25KBITS();
  can_filter_config_t fConfig = CAN_FILTER_CONFIG_ACCEPT_ALL();
  // Install CAN driver and return error code
  return can_driver_install(&gConfig, &tConfig, &fConfig);
My compiler (I'm using PlatformIO) takes issue with the config macro, saying " a value of type "int" cannot be used to initialize an entity of type "gpio_num_t" ". The function ensures that I could only possibly be passing gpio_num_ts rather than ints.
chegewara
Re: Compiler thinks I'm giving an int to the CAN_GENERAL_CONFIG_DEFAULT macro
Postby chegewara » Mon Jan 18, 2021 11:56 am
Its the difference between C and C++. You have to cast it with:
(int)canTxPin, (int) canRxPin
jrveale
Postby jrveale » Mon Jan 18, 2021 3:33 pm
Solution: Expanded the macro and found the issue is that CAN_IO_UNUSED is defined as an int rather than a gpio_num_t. Replaced the macro with the expanded form, and casting CAN_IO_UNUSED to gpio_num_t.
So
is replaced by
can_general_config_t gConfig = {
      .mode = canMode,
      .tx_io = canTxPin,
      .rx_io = canRxPin,
      .clkout_io = (gpio_num_t)CAN_IO_UNUSED,
      .bus_off_io = (gpio_num_t)CAN_IO_UNUSED,
      .tx_queue_len = 5,
      .rx_queue_len = 5,
      .alerts_enabled = CAN_ALERT_NONE,
      .clkout_divider = 0,
jrveale
Postby jrveale » Mon Jan 18, 2021 3:37 pm
Thanks chegewara, but the macro is expecting gpio_num_t not int.
The issue was due to C vs C++ differences but was hidden within the macro and had nothing to do with my inputs. CAN_IO_UNUSED is defined as an int rather than a gpio_num_t - turns out this has already been reported. https://github.com/espressif/esp-idf/issues/2825
Users browsing this forum: Baidu [Spider], Qwantbot and 0 guests
