[SPI Master] Data on MOSI is not the value we put in "spi_device_transmit()"
JonathanChen
Postby JonathanChen » Thu Feb 04, 2021 4:20 am
Esp32 works in spi master mode and keeps sending data to a spi slaver.
After more than 30 minutes,we found that sometimes the data on MOSI is different from the data which we put in "spi_device_transmit()".
Once the mismatch occurs. the scope stops and we take the picture like this:
channel 1 is spi clk;
channel 2 is spi mosi;
channel 3 is gpio signal from slaver(just to trig scope)
and we can find 8 pulses with no data on MOSI.
The spi mode is :
13.333Mhz
mode 3
HSPI_HOST
DMA enable
Help!!!!
code:
init part:
#define SPI_MISO_PIN 			13
#define SPI_MOSI_PIN 			12
#define SPI_CLK_PIN  			14
#define SPI_CS_PIN   			15
#define SPI_WAIT_PIN 			17
#define SPI_SPEED_HZ   			10000000
static spi_device_handle_t Spi_Init()
	esp_err_t ret;
	//doesn't work
	gpio_iomux_in(SPI_MISO_PIN,HSPID_IN_IDX);
	gpio_iomux_out(SPI_MOSI_PIN,HSPIQ_OUT_IDX,false);
	gpio_iomux_out(SPI_CLK_PIN,HSPICLK_OUT_IDX,false);
	gpio_iomux_out(SPI_CS_PIN,HSPICS0_OUT_IDX,false);
	spi_device_handle_t spi;
	spi_bus_config_t buscfg={
			.miso_io_num=SPI_MISO_PIN,
			.mosi_io_num=SPI_MOSI_PIN,
			.sclk_io_num=SPI_CLK_PIN,
			.quadwp_io_num=-1,
			.quadhd_io_num=-1,
			.flags = SPICOMMON_BUSFLAG_MASTER,
			.intr_flags = ESP_INTR_FLAG_IRAM
	spi_device_interface_config_t devcfg={
			.cs_ena_pretrans = 0,
			.cs_ena_posttrans = 10,
			.clock_speed_hz=SPI_SPEED_HZ,
			.mode=3,
			.spics_io_num=SPI_CS_PIN,
			.queue_size=1,
			.pre_cb=NULL,
			.flags = SPI_DEVICE_NO_DUMMY,
	spi_host_device_t spiName = HSPI_HOST;
	//Initialize the SPI bus
	ret=spi_bus_initialize(spiName, &buscfg, 2);
	assert(ret==ESP_OK);
	//Attach the DEVICE to the SPI bus
	ret=spi_bus_add_device(HSPI_HOST, &devcfg, &spi);
	spiTxBuf = (uint8_t *)heap_caps_malloc(512, MALLOC_CAP_DMA);/
	spiRxBuf = (uint8_t *)heap_caps_malloc(512, MALLOC_CAP_DMA);
	return spi;
Trans part:
	spi_transaction_t t;
	memset(&t, 0, sizeof(t));
	memset(spiTxBuf, 0, 512);
	memset(spiRxBuf, 0, 512);
	spiTxBuf[0] = 0xaa;
	t.length=8;
	t.tx_buffer=spiTxBuf;
	ret=spi_device_transmit(spi, &t);
Re: [SPI Master] Data on MOSI is not the value we put in "spi_device_transmit()"
Postby Sprite » Thu Feb 04, 2021 4:29 am
You did not manage to add a picture... Also, can you share the code that does the transmission?
JonathanChen
Postby JonathanChen » Thu Feb 04, 2021 4:40 am
Sorry :D
now i have update the img and code
please check.
Postby Sprite » Thu Feb 04, 2021 5:35 am
Strange... your code itself looks good. What ESP-IDF version are you using? What else is your code doing?
JonathanChen
Postby JonathanChen » Thu Feb 04, 2021 5:44 am
Release 3.3.4
hardware :esp32-wroom-32
My code has almost 10~15 tasks ,and WIFI, LWIP and BLE.
And I will check the value in " spiTxBuf[0]" before put it in "spi_device_transmit";
For now ,we try to make sure if there is some bug in our code.
Scott.Bonomi
Postby Scott.Bonomi » Thu Feb 04, 2021 5:17 pm
JonathanChen -
For your anomaly tracing, it is often very worthwhile to use the Chip Select line down transition as a trigger for the scope.
- - Scott
JonathanChen
Postby JonathanChen » Fri Mar 12, 2021 2:14 am
update the code with idf-4.3-beta1.
And after a long test, it works well.
May be we solved it. :D :D :D :D :D
Users browsing this forum: Qwantbot and 8 guests
