LoRa Ra-02 SX1278 Module 433MHz
I have the ESP32 WROOM and I have it together with the LoRa Ra-02 SX1278 Module 433MHz. Now I have some example files in micropython. But I can no longer get into the shell when I press stop, nor when I put the USB cable in and out. He keeps booting that script. I am using the editor Thonny. How can I get back into the shell.
Re: LoRa Ra-02 SX1278 Module 433MHz
Hi...I am using Arduino Uno, SX1278 LoRa Ra02 433MHz module and 433MHz antennas to send message to a receiver which has the same hardware. Sender is sending just one packet then stops(receiver takes the only message in good RSSI).What kind of loop or code can use to make sender to send continuously?
Moderator note: This was a spambot probably copy/pasting a question from somewhere else. I'm letting the message remain here as someone already replied to it.
I use micropython, But on github are a lot scripts for the arduino.
Are you using two LoRa Ra-02 SX1278 Module 433MHz ?
Users browsing this forum: PerplexityBot and 2 guests
