uxTaskGetStackHighWaterMark Appears to be in Bytes
oklambdago
Postby oklambdago » Tue Mar 23, 2021 2:38 pm
Hi All,
Per the documentation, uxTaskGetStackHighWaterMark is supposed to be in words: https://docs.espressif.com/projects/esp ... skHandle_t
However, this does not appear to be so. When I create a task, I am clear the task stack size is specified in bytes: https://docs.espressif.com/projects/esp ... skHandle_t
However, when I call uxTaskGetStackHighWaterMark on a task with a stack size of 8192 bytes, I am getting back values like 6036. This value only makes sense if the value it returns is in bytes. Otherwise it would mean the minimum free was ~24k, which greatly exceeds the value I specified for the task size in xTaskCreate().
Can someone clarify if the documentation is wrong on this?
Thanks!
chegewara
Re: uxTaskGetStackHighWaterMark Appears to be in Bytes
Postby chegewara » Tue Mar 23, 2021 6:05 pm
this is just copy/paste error.
Vanilla freertos is using dword for creating task and stack watermark. esp-idf is using bytes as base size in both functions.
oklambdago
Postby oklambdago » Tue Mar 23, 2021 9:07 pm
Thanks! That is a very helpful thing to know. Hopefully there are plans to update the documentation soon!
Angus
Postby Angus » Tue Mar 23, 2021 11:52 pm
Hi oklambdago,
Thanks very much for pointing this out, sorry for the confusion. It looks like a regression in the function's doxygen comment when we updated to FreeRTOS 10 (the docs for the stable ESP-IDF version has the correct description).
I've just submitted a fix for this internally.
Users browsing this forum: Baidu [Spider], Bytespider, ChatGPT-User, PetalBot and 1 guest
