I was wondering if it is possible that the ESP32 goes into deepsleep while doing an OTA update ?
If not, what are the mechanisms that ensure that the OTA is not interrupted if while doing an OTA.
If so, how to prevent it ?
Thanks,
Charles
OTA and deepsleep
Re: OTA and deepsleep
No, OTA is using WiFi and then you can not use deep sleep. In you code you can setup a funktion to run when OTA starts, set a variable to true and then disable everything else when it is true.
Users browsing this forum: Amazon [Bot], PerplexityBot, Qwantbot and 2 guests
