when use ESP-WROVER-KIT,always getting the message"Localhost:3333:Connection timed out."
roctwo
Postby roctwo » Wed Apr 05, 2017 7:06 am
I want to use ESP-WROVER-KIT to do JTAG debugging for ESP32,when I OpenOCD,run the command"xtensa-esp32-elf-gdb -ex 'target remote localhost:3333' ./build/app-template.elf",always getting the wrong mesagge"localhost:3333: Connection timed out."
What am I missing ? Maybe some access right ?
thanks for your help,
regards,
Alisa
Re: when use ESP-WROVER-KIT,always getting the message"Localhost:3333:Connection timed out."
Postby Sprite » Wed Apr 05, 2017 7:18 am
Are you sure the OpenOCD process is running when you run the gdb command? Can you copy/paste the output of openocd here?
roctwo
Postby roctwo » Wed Apr 05, 2017 8:41 am
Hi dear,
You are right,the OpenOCD process is not running,I run the OpenOCD commend"./src/openocd -s ./tcl -f ./esp.cfg" again,it show"Remote debugging using localhost:3333",but it may be has another question as below:
Ignoring packet error,continuing...
warning:unrecognized item "time out" in "qSupported" response
Bogus trace status reply from target:timeout
(gdb)
By the way,when I run the "./src/openocd -s ./tcl -f ./esp.cfg",the printing run all the time,It can't been halted even I press the reset button on the ESP-WROVER-KIT borad.
roctwo
Postby roctwo » Thu Apr 06, 2017 1:57 am
Hi dear,
After yesterday debugging,I get this wrong message as below:
0x00000000 in ?? ()
(gdb) b app_main
Breakpoint 1 at 0x401085f4:file app_main.c,line 35
(gdb)c
Continuing.
Warning:
Cannot insert breakpoint1.
Cannot access memory at address 0x401085f4
Is there something wrong for my operation ?
regards,
Alisa
Postby Sprite » Thu Apr 06, 2017 2:17 am
Can you post the output of OpenOCD here? It almost seems like something else is listening on port 3333 on your machine...
roctwo
Postby roctwo » Thu Apr 06, 2017 3:38 am
Hi dear,
The output of OpenOCD as attachment,pls help to review,thanks~
output of OpenOCD.doc
(72 KiB) Downloaded 913 times
Postby Sprite » Thu Apr 06, 2017 12:33 pm
Hum. All I can see (and say) is that there's something going terribly wrong with the communication between the JTAG chip and the ESP32. Can you post a picture of the kit so I can see which jumpers are installed?
rapzakesp
Postby rapzakesp » Thu Apr 06, 2017 1:19 pm
I have increased the base resistor on Q1 & Q2 - i think it was 10k i putted on...
/Rapzak
roctwo
Postby roctwo » Fri Apr 07, 2017 1:06 am
Hi dear,
Pls review the esp-wrover-kit connection as attchment. To enable the JTAG function, I use shorting jumpers on JP8 (JTAG) for TMS、TDO、TDI、TCK、GND.
By the way,the GPIO12、GPIO13、GPIO14、GPIO15 can be reused?I may be use these GPIO to connect Camera.
Postby Sprite » Fri Apr 07, 2017 4:39 am
Are you using GPIO12/13/14/15 right now? Because if that is the case, that is the reason your JTAG does not work: re-using the pins for different purposes is possible, but it will kill JTAG connectivity in weird and interesting ways and may lead to what you've seen.
Users browsing this forum: ChatGPT-User, Google [Bot], Qwantbot and 1 guest
