绿灯GPIO28无法正常亮灯,电压约2.0V
ESP-IDF版本
ESP-IDF v4.3-beta3-131-ge45be4dd4
demo:
simple_ota
code:
Code: Led.c Select all
#define CONFIG_GREEN_LED_GPIO 28
#define CONFIG_RED_LED_GPIO 37
#define GREEN_LED_GPIO CONFIG_GREEN_LED_GPIO
#define RED_LED_GPIO CONFIG_RED_LED_GPIO
#define Led_Set_Red_On() gpio_set_level(RED_LED_GPIO, 0)
#define Led_Set_Green_On() gpio_set_level(GREEN_LED_GPIO, 0)
#define Led_Set_Red_Off() gpio_set_level(RED_LED_GPIO, 1)
#define Led_Set_Green_Off() gpio_set_level(GREEN_LED_GPIO, 1)
gpio_config_t cfg = { .pin_bit_mask = BIT64(GREEN_LED_GPIO),
.mode = GPIO_MODE_OUTPUT,
//for powersave reasons, the GPIO should not be floating
.pull_up_en = false,
.pull_down_en = false,
.intr_type = GPIO_INTR_DISABLE, };
Led_Set_Green_On();
gpio_config(&cfg);
gpio_set_drive_capability(GREEN_LED_GPIO, GPIO_DRIVE_CAP_3);
gpio_hold_dis(GREEN_LED_GPIO);
gpio_hold_en(GREEN_LED_GPIO);
Led_Set_Red_On();
cfg.pin_bit_mask = BIT64(RED_LED_GPIO);
gpio_config(&cfg);
gpio_set_drive_capability(RED_LED_GPIO, GPIO_DRIVE_CAP_3);
gpio_hold_dis(RED_LED_GPIO);
gpio_hold_en(RED_LED_GPIO);
