Connecting with Wifi using AP mode
rajatjain313
Postby rajatjain313 » Mon May 31, 2021 7:10 am
Hi. I am wanting to create a web page where i can enter wifi details so that my esp32 wroom 32E can save the wifi settings and publish data using mqtt. So when i turn on esp32, we put the device on AP mode, open a url (10.10.10.10 as example) which is preset in the code in esp32. once the page opens we enter wifi details and other settings as required after which it should store the settings. once it is in publish mode, it should connect with the wifi and transmit data using mqtt. kindly help
Re: Connecting with Wifi using AP mode
Postby Sprite » Tue Jun 01, 2021 12:37 am
You probably want to look into something like this.
Users browsing this forum: Baidu [Spider], Google [Bot], Qwantbot, Semrush [Bot] and 1 guest
