Wifi station example and ESP32-S2
timokett
Postby timokett » Thu Jun 17, 2021 12:23 pm
I have been going through the ESP32 sample codes in examples folder.
I have ESP32-S2 WROVER and I am using internal USB CDC instead of serial converter.
When I build and run the sample examples/wifi/getting_started/station, I get no console output.
The device seems to reboot in a loop idf.py monitor saying:
device reports readiness to read but returned no data (device disconnected or multiple access on port?)
Waiting for the device to reconnect..
The app has following code (printf by me):
Code: Untitled.c Select all
void app_main(void)
printf("** started\n");
//Initialize NVS
esp_err_t ret = nvs_flash_init();
printf("** initialized\n");
if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) {
ESP_ERROR_CHECK(nvs_flash_erase());
ESP_ERROR_CHECK(ret);
ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
wifi_init_sta();
This outputs nothing.
If I comment the nvs_flash_init and related error checks away, I get the printf outputs but the app fails later, of course.
Should this station sample work with ESP32-S2? Any ideas?
Re: Wifi station example and ESP32-S2
Postby Sprite » Fri Jun 18, 2021 12:28 am
Could be a brownout. What's the power supply to the S2 look like? If you're using a devboard, perhaps try a different USB cable?
timokett
Postby timokett » Tue Jun 22, 2021 3:25 pm
Brownout is not likely since the dev board supports lipo battery and I have it also connected.
bbinet
Postby bbinet » Tue Jun 22, 2021 10:46 pm
I have the exact same issue.
I've tried with multiple USB cables but the issue remains.
If I make a basic example which only make the ESP32S2 led to blink, but does not use the NVS nor call nvs_flash_init(); then the device led blinks as expected and the usb console works perfectly.
So there must be an issue with the NVS stuff.
I tried to erase_flash the device, but it does not help: same issue after the flash has been erased.
timokett
Postby timokett » Wed Jun 23, 2021 6:09 pm
I now found out that when I loop a while before going into nv_init, it works.
I merged the led blink example with station example to add few blinks at the beginning:
void app_main(void)
ESP_LOGI(TAG, "Started");
#if 1
/* Configure the peripheral according to the LED type */
configure_led();
int times = 5;
while (--times > 0) {
ESP_LOGI(TAG, "Turning the LED %s!", s_led_state == true ? "ON" : "OFF");
blink_led();
/* Toggle the LED state */
s_led_state = !s_led_state;
vTaskDelay(CONFIG_BLINK_PERIOD / portTICK_PERIOD_MS);
#endif
//Initialize NVS
When blinking is included, the code works fine. When it is not (#if 0), it behaves as before.
I will experiment more later, now I will be five days away...
ESP32-S2-WROVER-DevKit-LiPo-USB
bbinet
Postby bbinet » Thu Jun 24, 2021 7:28 am
Waiting a few sec before initializing NVS indeed fix the issue.
This is an easy workaround, thank you @timokett.
timokett
Postby timokett » Wed Jul 07, 2021 6:38 am
I found out that 500 ms is enough, 100 ms was not.
So I added this in the beginning and it works fine:
vTaskDelay(500 / portTICK_PERIOD_MS);
