When I try to run the following command:
idf.py -DVENDOR=espressif -DBOARD=esp32_devkitc -DCOMPILER=xtensa-esp32 buildCode: Select all
/Users/jagaty/esp/esp-idf/components/newlib/platform_include/time.h:28:19: error: unknown type name 'clockid_t'; did you mean '_lock_t'?
int clock_settime(clockid_t clock_id, const struct timespec *tp);
_lock_t
/Users/jagaty/esp/esp-idf/components/newlib/platform_include/time.h:29:19: error: unknown type name 'clockid_t'; did you mean '_lock_t'?
int clock_gettime(clockid_t clock_id, struct timespec *tp);
_lock_t
/Users/jagaty/esp/esp-idf/components/newlib/platform_include/time.h:30:18: error: unknown type name 'clockid_t'; did you mean '_lock_t'?
int clock_getres(clockid_t clock_id, struct timespec *res);
_lock_t
In file included from /Users/jagaty/Documents/Experiments/OTA_Test/FreeRTOS/libraries/3rdparty/mbedtls/include/mbedtls/platform.h:68,
from /Users/jagaty/Documents/Experiments/OTA_Test/FreeRTOS/vendors/espressif/esp-idf/components/mbedtls/port/mbedtls_debug.c:18:
/Users/jagaty/Documents/Experiments/OTA_Test/FreeRTOS/libraries/3rdparty/mbedtls/include/mbedtls/platform_time.h:78:9: error: unknown type name 'time_t'
typedef time_t mbedtls_time_t;System information
Hardware board: [https://shop.m5stack.com/products/esp32 ... a-x-ov3660](ESP32 DevkitC)
IDE used: VS Code & command line
Operating System: MacOS
Code version: latest - downloaded from AWS Console
Project/Demo: OTA
References:
Full stack trace on this link: https://github.com/aws/amazon-freertos/ ... /error.txt
Steps to reproduce the current status
Download FreeRTOS with OTA demo enabled from AWS console onto the MAC.
ESP32 specific setup
Complete the prerequisites
Run idf.py -DVENDOR=espressif -DBOARD=esp32_devkitc -DCOMPILER=xtensa-esp32 build from the FreeRTOS directory.Similar issue: https://github.com/aws/amazon-freertos/ ... -769577330
Github issue: https://github.com/aws/amazon-freertos/issues/3347
But I cannot find any solution mentioned to the issue.
Would appreciate any help!
