esp32c3 arduino ide my code is not executed
khoih-prog
Re: esp32c3 arduino ide my code is not executed
Postby khoih-prog » Mon Aug 23, 2021 5:03 pm
FYI, Problem still persists in ESP32 Arduino 2.0.0 RC2 and Arduino IDE 1.8.15
After reupload with ESP32_DEV
xx⸮xxxx⸮⸮x⸮⸮x⸮⸮x⸮⸮x⸮x⸮xx⸮⸮⸮⸮⸮⸮x⸮⸮xxxxx⸮⸮x⸮xx⸮⸮⸮⸮⸮⸮⸮x⸮⸮⸮⸮⸮
ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd6100,len:0x1428
load:0x403ce000,len:0xc04
load:0x403d0000,len:0x292c
entry 0x403ce000
I (30) boot: ESP-IDF v4.4-dev-2313-gc69f0ec32 2nd stage bootloader
I (30) boot: compile time 12:10:14
I (30) boot: chip revision: 3
I (30) boot_comm: chip revision: 3, min. bootloader chip revision: 0
I (37) qio_mode: Enabling default flash chip QIO
I (41) boot.esp32c3: SPI Speed      : 80MHz
I (45) boot.esp32c3: SPI Mode       : QIO
I (49) boot.esp32c3: SPI Flash Size : 2MB
I (52) boot: Enabling RNG early entropy source...
I (57) boot: Partition Table:
I (59) boot: ## Label            Usage          Type ST Offset   Length
I (66) boot:  0 nvs              WiFi data        01 02 00009000 00005000
I (72) boot:  1 otadata          OTA data         01 00 0000e000 00002000
I (79) boot:  2 app0             OTA app          00 10 00010000 00140000
I (85) boot:  3 spiffs           Unknown data     01 82 00150000 000b0000
I (92) boot: End of partition table
I (95) boot_comm: chip revision: 3, min. application chip revision: 0
I (101) esp_image: segment 0: paddr=00010020 vaddr=3c030020 size=08c60h ( 35936) map
I (114) esp_image: segment 1: paddr=00018c88 vaddr=3fc8b600 size=0155ch (  5468) load
I (117) esp_image: segment 2: paddr=0001a1ec vaddr=40380000 size=05e2ch ( 24108) load
I (128) esp_image: segment 3: paddr=00020020 vaddr=42000020 size=23db4h (146868) map
I (152) esp_image: segment 4: paddr=00043ddc vaddr=40385e2c size=056ech ( 22252) load
I (156) esp_image: segment 5: paddr=000494d0 vaddr=50000000 size=00010h (    16) load
I (160) boot: Loaded app from partition at offset 0x10000
I (161) boot: Disabling RNG early entropy source...
Starting ISR_16_Timers_Array_Complex on ESP32C3_DEV
ESP32_New_TimerInterrupt v1.0.0
CPU Frequency = 160 MHz
Starting ITimer OK, millis() = 2188
SimpleTimer : 2, ms : 12203, Dms : 10005
Timer : 0, programmed : 5000, actual : 5000
Timer : 1, programmed : 10000, actual : 10000
Timer : 2, programmed : 15000, actual : 0
Timer : 3, programmed : 20000, actual : 0
Timer : 4, programmed : 25000, actual : 0
Timer : 5, programmed : 30000, actual : 0
Timer : 6, programmed : 35000, actual : 0
Timer : 7, programmed : 40000, actual : 0
Timer : 8, programmed : 45000, actual : 0
Timer : 9, programmed : 50000, actual : 0
Timer : 10, programmed : 55000, actual : 0
Timer : 11, programmed : 60000, actual : 0
Timer : 12, programmed : 65000, actual : 0
Timer : 13, programmed : 70000, actual : 0
Timer : 14, programmed : 75000, actual : 0
Timer : 15, programmed : 80000, actual : 0
SimpleTimer : 2, ms : 22269, Dms : 10066
chegewara
Postby chegewara » Tue Aug 24, 2021 7:14 am
I cant tell why you are having this issue, i can only say i am using C3 rev2 with UART and C3 rev3 with USB interface and i dont have any problems with flashing them.
Maybe you have to update toolchain/esptool with get.py/get.exe.
khoih-prog
Postby khoih-prog » Tue Aug 24, 2021 5:17 pm
I'm using Python 2.7.18 (default, Mar 8 2021, 13:02:45) and esptool_py v3.1.0 and the following is the Arduino IDE uploading commands
Sketch uses 232542 bytes (17%) of program storage space. Maximum is 1310720 bytes.
Global variables use 10436 bytes (3%) of dynamic memory, leaving 317244 bytes for local variables. Maximum is 327680 bytes.
python /home/kh/.arduino15/packages/esp32/tools/esptool_py/3.1.0/esptool.py --chip esp32c3 --port /dev/ttyUSB1 --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 /home/kh/.arduino15/packages/esp32/hardware/esp32/2.0.0-rc2/tools/partitions/boot_app0.bin 0x0 /tmp/arduino_build_607689/ISR_16_Timers_Array_Complex.ino.bootloader.bin 0x10000 /tmp/arduino_build_607689/ISR_16_Timers_Array_Complex.ino.bin 0x8000 /tmp/arduino_build_607689/ISR_16_Timers_Array_Complex.ino.partitions.bin
esptool.py v3.1
Serial port /dev/ttyUSB1
Connecting....
Chip is unknown ESP32-C3 (revision 3)            <===========  Strange here
Features: Wi-Fi
Crystal is 40MHz
MAC: 7c:df:a1:b6:ab:f0
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 2MB
Flash will be erased from 0x00000000 to 0x00004fff...
Flash will be erased from 0x00010000 to 0x00049fff...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.2 seconds (effective 420.0 kbit/s)...
Hash of data verified.
Compressed 18864 bytes to 11759...
Writing at 0x00000000... (100 %)
Wrote 18864 bytes (11759 compressed) at 0x00000000 in 0.7 seconds (effective 206.1 kbit/s)...
Compressed 234768 bytes to 113604...
Writing at 0x00010000... (14 %)
Writing at 0x0001a7f2... (28 %)
Writing at 0x00021148... (42 %)
Writing at 0x0002913d... (57 %)
Writing at 0x0002fb6b... (71 %)
Writing at 0x00037bc4... (85 %)
Writing at 0x00042f02... (100 %)
Wrote 234768 bytes (113604 compressed) at 0x00010000 in 3.9 seconds (effective 475.5 kbit/s)...
Compressed 3072 bytes to 118...
Wrote 3072 bytes (118 compressed) at 0x00008000 in 0.1 seconds (effective 271.3 kbit/s)...
Leaving...
Hard resetting via RTS pin...
It's possible some bug of Arduino esp32 core as it's still OK with esp-idf.
I'm afraid this issue is board dependent and will order some different boards to try and see.
The current board is Image
and ordered from https://www.aliexpress.com/item/1005002783695684.html
