scanf() don't work in idf monitor
axel_hpplt
Postby axel_hpplt » Thu Aug 26, 2021 9:08 pm
I am a new user on esp-idf. I have done some tests after following the "Getting Started" section, including this one:
Code: Untitled.c Select all
#include <stdio.h>
void app_main(void)
char chr;
printf("Enter Data : ");
scanf("%c", &chr);
printf("Data entered : %c.", chr);
Everything goes well, I start the monitor with the command "idf.py -p COM3 monitor". It is displayed : "Enter Data : " but I can't write anything, as if the keyboard was not working. However the CTRL-C (keyboard interrupt) command works. Do you know why I can't write anything in this monitor ?
Thank you in advance for your help,
AH.
Minatel
Re: scanf() don't work in idf monitor
Postby Minatel » Fri Aug 27, 2021 10:17 am
You need to use the console approach. See this example:
https://github.com/espressif/esp-idf/tr ... sole/basic
axel_hpplt
Postby axel_hpplt » Fri Aug 27, 2021 2:26 pm
First of all, thank you so much for your response! I looked at what you sent me, I may be blind but I don't really see how it helps me with my problem. It did help me start to understand the "console" approach but I don't see how I can "replace" my lines of code.
Minatel
Postby Minatel » Fri Aug 27, 2021 3:14 pm
Are you trying to do something similar to this thread?
Reading character input from the serial port
See also the UART Select Example.
axel_hpplt
Postby axel_hpplt » Fri Aug 27, 2021 10:29 pm
I found a solution that seems to fit:
#include <stdio.h>
#include <string.h>
#include "esp_system.h"
#include "esp_console.h"
#include "esp_vfs_dev.h"
#include "esp_vfs_fat.h"
#include "driver/uart.h"
void app_main(void)
setvbuf(stdin, NULL, _IONBF, 0);
setvbuf(stdout, NULL, _IONBF, 0);
ESP_ERROR_CHECK(uart_driver_install(CONFIG_ESP_CONSOLE_UART_NUM, 256, 0, 0, NULL, 0));
esp_vfs_dev_uart_use_driver(CONFIG_ESP_CONSOLE_UART_NUM);
esp_vfs_dev_uart_port_set_rx_line_endings(CONFIG_ESP_CONSOLE_UART_NUM, ESP_LINE_ENDINGS_CR);
esp_vfs_dev_uart_port_set_tx_line_endings(CONFIG_ESP_CONSOLE_UART_NUM, ESP_LINE_ENDINGS_CRLF);
char chr[10];
while(1){
scanf("%9s\n", chr);
printf("\nData entered : %s.\n", chr);
The above program works well, I enter a string in the console (10 maximum), and when I press "Enter" the code displays the previously entered string. However, some problem persists:
- Sometimes there is a bug that appears randomly:
I think it's a display bug but I'm not sure.
- The characters are not displayed as I type them on the keyboard. They only appear once I press "Enter".
- Last problem, once I type the string and press "Enter" the string does not appear. It only appears once I start writing the new string.
I would like to know if there are any solutions to solve these problems.
ekawahyu
Postby ekawahyu » Tue Nov 16, 2021 5:39 pm
@axel_hpplt Thank you for posting this solution, and I got a fix for you. Instead of using
, remove the trailing
scanf("%9s", chr);
and you should be good to go.
EnthusiastGuy
Postby EnthusiastGuy » Thu Sep 01, 2022 7:59 pm
Thank you very much for this!
I am able to confirm that this program works excellent with ESP-IDF 4.4 in order to take commands from the PC by means of Serial communication with the ESP32 board (in my case):
#include <stdio.h>
#include <string.h>
void app_main(void)
    setvbuf(stdout, NULL[Codebox][/Codebox], _IONBF, 0);
    char chr[10];
    while(1){
        scanf("%9s", chr);	// thanks ekawahyu!
I have one question. Since the scanf waits for the input, is there any alternative that would instead not interrupt execution and only come into function if actual content comes from the uart? My first guess is that I'd have to check for data first and if it exists, then do the scanf, but I am unfamiliar with the API and I'm actually not sure whether I'd run into an exhaust state or race condition there.
Thanks!
Postby Sprite » Fri Sep 02, 2022 12:50 am
You'd need to collect the characters from the UART into a string yourself, and when you get a newline, you can run sscanf() on that.
Users browsing this forum: meta-externalagent, trendictionbot and 5 guests
