ESP32-S3-WROOM-1 preferred PINs for I2C and CAN
MartinHaiden
Postby MartinHaiden » Fri Sep 03, 2021 8:23 am
Hello ESP32 Community! :)
I'd like to use the ESP32-S3 with I2C and CAN Bus communications.
Are there preferred PINs on the ESP32-S3 for this purpose?
Like for SPI (IO9 to IO14).
kind regards,
Martin
Re: ESP32-S3-WROOM-1 preferred PINs for I2C and CAN
Postby Sprite » Sat Sep 04, 2021 1:56 am
No, there are not. You can pick any pin for this (that is not input-only or used for other things like flash).
dmaxben
Postby dmaxben » Mon Sep 13, 2021 3:36 pm
Can you use an input-only pin for TWAI-Rx?
Postby Sprite » Tue Sep 14, 2021 1:08 am
You can; it's OK to use input-only pins for input-only functionality. (Thanks for pointing that out, it slipped my mind that CAN has a RX pin before the transceiver.)
