custom new/delete
dontpostalot
custom new/delete
Postby dontpostalot » Wed Sep 15, 2021 1:11 pm
I' trying to override the new/delete operators to add some data to any dynamically allocated memory, like this:
void * operator new(size_t size)
	size_t* ret = (size_t*)malloc(size + sizeof(size_t*));
	*ret = 0;
	ret++;
	return (void*)ret;
void operator delete(void * ptr)
	size_t* ptrmem = (size_t*)ptr;
	ptrmem--;
	free((void*)ptrmem);
But the ESP32 errors (CORRUPT HEAP) and reboots. This does work on other compilers/architectures like MSC. What could be done to make this trick work?
Re: custom new/delete
Postby Sprite » Thu Sep 16, 2021 1:17 am
Not sure if that's it, but
I assume you want to add an extra size_t at the beginning of the allocated struct? In that case, your sizeof is wrong, it should be
	size_t* ret = (size_t*)malloc(size + sizeof(size_t));
(Also, entirely offtopic, I'm surprised how quickly the word 'size' leads to semantic saturation.)
dontpostalot
Postby dontpostalot » Thu Sep 16, 2021 7:37 am
No, sizeof(size_t) equals sizeof(size_t*), 4 on the ESP32. I was thinking what if there's a 'new' running before my sketch and the memory is released with my custom delete, that would cause a corrupted heap. So I used the extra memory as a tag, turns out there are 5 objects getting deleted that weren't created by the custom 'new'. The following sketch DOES run and prints out 5 continuously:
int cntbad = 0;
  *ret = 37; // tag it!
  ret++;
  return (void*)ret;
void operator delete(void * ptr) noexcept
  ptrmem--;
  if (*ptrmem != 37) { // not generated by our new
    ptrmem++;
    cntbad++;
void setup() {
  Serial.begin(115200, SERIAL_8N1);
void loop() {
Serial.println("loep");
Serial.println(cntbad);
delay(1000);
Of course I can't tag all these pieces of memory, that wouldn't be very efficient, but maybe it's just the first 5 objects that are being deleted. So I changed the line that said 'if (*ptrmem != 37)' to 'if (cntbad < 5)', and it all still worked fine.
This is an acceptable workaround imo, but it still feels wrong. Whatever code is initing my sketch shouldn't call new or delete at all. If anyone has a better solution please let me know.
