intelligently avoiding a fatal stack overflow crash?
societyofrobots
Postby societyofrobots » Sun Sep 19, 2021 1:12 am
I have a file, X, that logs events and is stored in SPIFFS.
Once every few months, X fills up SPIFFS. When that happens, my software prunes older data from the log.
To do this, I:
- create String S
- copy only the newer half of file X into string S
- dump S into a new file, Y
- then I delete X, using Y as the new log
This code is working great for me, but...
I am concerned that one day for unforeseen reasons my available memory (stack?) could be less than the size of S. Boom, overflow.
Is there a way to ensure S won't overflow the stack? Could I check for free memory, thereby limiting data into S?
I could just appendFile(), byte by byte, from X to Y, without using S. But...
I also serve S in a webpage for users to view the log:
server.send(200, "text/html", S);
Any advice? I'm not the most skilled of programmers, so dumb it down for me!
WiFive
Re: intelligently avoiding a fatal stack overflow crash?
Postby WiFive » Sun Sep 19, 2021 4:02 am
Yes, don't put S in the stack. Put it in the heap and make sure you don't write more than its size.
Plenty of web server examples that can serve files from spiffs.
societyofrobots
Postby societyofrobots » Sun Sep 19, 2021 11:57 pm
How do I control whether S is put in the stack or heap?
Thanks I'll look into it.
Some code I figured out which should be 'good enough' to make sure S will be smaller than the available heap...
if(file.size() > ESP.getMaxAllocHeap()-10000)
   prune();
Users browsing this forum: Baidu [Spider], Bing [Bot], coccocbot, Qwantbot and 3 guests
