Need sample code for ILI9488 LCD on SPI Interface
Re: Need sample code for ILI9488 LCD on SPI Interface
The repository will be updated in the next couple of days.
I've made many changes to make it work faster and better. Jpeg image drawing will be fixed and bmp format added.
I'm also working on documenting all the functions.
Thanks for quick reply...
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hi Loboris,
If possible then can you please update your current Repository with JPEG image dotted issue as we require that fix ASAP?
It will be more helpful for me if you can provide that fix as quickly as possible because we have made lot many changes on top of your example to meet our application requirement.
Also, we need to showcase that demo to client as well as quickly as possible. It will be good if you provide other fixes later on based your schedule.
Regards,
Ritesh Prajapati
Ritesh Prajapati
I hope you are paying this guy for his hard work.Hi Loboris,
@Ritesh
Not completed yet, but I've commited the changes to GitHub.
Good idea
https://www.paypal.com/cgi-bin/webscr?c ... E5RV6MVM2U
- jpeg problem fixed
- bmp format added (displayed in example)
- default color mode is now 18-bit
- added new color structure color_t {r,g,b} which is used with all color operations
- added option to use DMA transfer in some operations where it makes sense (for example jpg decoding)
- source restructured
- I've discovered that ESP32 has jpeg decoder included in ROM, so tjpgd.c is removed and tjpgd.h from esp-idf is used
- not yet fully documented
Good idea
https://www.paypal.com/cgi-bin/webscr?c ... E5RV6MVM2URe: Need sample code for ILI9488 LCD on SPI Interface
Thanks for quick reply..@Ritesh
Not completed yet, but I've commited the changes to GitHub.@WiFive
Good idea![]()
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hi Loboris,
I just gone through your code and found that you are trying to port VFAT file system as well but somehow not able to success it as per your commented code. Also, you are moving from default partition to custom partition.
So, We have already ported SPIFFS file system for both ESP32 and ESP8266 and made it generic for both chip usage.
Please let me know if you need any help to port SPIFFS file system for ESP32.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hi Loboris,
Please find attached compressed file in which I have added SPIFFS file system component, one basic SPIFFS USer Guide Document and one example for how to use different SPIFFS APIs.
So, You can integrate it into your existing component or IDF component and can use SPIFFS file system into your repository.
Let me know if you need any help from my-side regarding that SPIFFS.
- esp32_spiffs_modified.7z
- ESP32 SPIFFS File System Usage
- (56.07 KiB) Downloaded 791 times
Regards,
Ritesh Prajapati
Ritesh Prajapati
@Ritesh
GitHub repository is now updated with some changes, bug fixes, optimization, cleaning ...
Option to display in grayscale mode is added
esp-idf's Wear leveling FAT file system is now used to demonstrate displaying jpg image from file (esp-idf commit of 5. May 2017 or later must be used).
Some more documentation is added in *.h files.
Thanks for spiffs info, I'm using spiffs for couple of months and with VFS so that regular file related function can be used (fopen, fclose, fread, fwrite, etc.). I've also added directories and file timestamp features. Maybe I'll put it as an example on GitHub.
I (1695) cpu_start: Pro cpu start user code
I (1748) cpu_start: Starting scheduler on PRO CPU.
I (1751) [SPI_FS]: Mounting FAT filesystem
E (1753) [SPI_FS]: FATFS mounted
E (1756) [SPI_FS]: JPG image found on file system
spi_master_nodma demo, LoBo 05/2017
SPI: display device added to spi bus
SPI: attached display device, speed=8000000
SPI: bus uses native pins: true
SPI: display init...
OK
Disp clock = 8.00 MHz (requested: 8.00)
Lines = 1396 ms (320 lines of 480 pixels)
Read check OK, line 218
Pixels = 4151 ms (480x320)
Cls = 475 ms (480x320)
Disp clock = 10.00 MHz (requested: 10.00)
Lines = 1395 ms (320 lines of 480 pixels)
Read check OK, line 293
Pixels = 3572 ms (480x320)
Cls = 382 ms (480x320)
Disp clock = 16.00 MHz (requested: 16.00)
Lines = 1394 ms (320 lines of 480 pixels)
Read check OK, line 300
Pixels = 2718 ms (480x320)
Cls = 244 ms (480x320)
### MAX READ SPI CLOCK set to 16.00 MHz ###
Disp clock = 26.67 MHz (requested: 30.00)
Lines = 1393 ms (320 lines of 480 pixels)
Read check Err, on line 232 at 17 (Read clock = 30.00 MHz)
Pixels = 2131 ms (480x320)
Cls = 152 ms (480x320)
Disp clock = 40.00 MHz (requested: 40.00)
Lines = 1392 ms (320 lines of 480 pixels)
Read check OK, line 163 (Read clock = 16.00 MHz)
Pixels = 1835 ms (480x320)
Cls = 106 ms (480x320)
Graphics demo started
DMA mode: OFF
GRAYSCALE mode: OFF
Clear screen time: 226 ms
Display line time: 720 us
JPG Decode time: 411 ms
Decode JPG (file): 411 ms
BMP Decode time: 768 ms
DMA mode: ON
GRAYSCALE mode: OFF
Clear screen time: 106 ms
Display line time: 341 us
JPG Decode time: 211 ms
Decode JPG (file): 211 ms
DMA mode: OFF
GRAYSCALE mode: ON
Clear screen time: 453 ms
Display line time: 1586 us
JPG Decode time: 742 ms
Decode JPG (file): 742 ms
BMP Decode time: 1103 ms
DMA mode: ON
GRAYSCALE mode: ON
Display line time: 958 us
JPG Decode time: 557 ms
Decode JPG (file): 557 ms
Thanks for update.@Ritesh
I (1695) cpu_start: Pro cpu start user code I (1748) cpu_start: Starting scheduler on PRO CPU. I (1751) [SPI_FS]: Mounting FAT filesystem E (1753) [SPI_FS]: FATFS mounted E (1756) [SPI_FS]: JPG image found on file system =================================== spi_master_nodma demo, LoBo 05/2017 =================================== SPI: display device added to spi bus SPI: attached display device, speed=8000000 SPI: bus uses native pins: true SPI: display init... OK ------------- Disp clock = 8.00 MHz (requested: 8.00) Lines = 1396 ms (320 lines of 480 pixels) Read check OK, line 218 Pixels = 4151 ms (480x320) Cls = 475 ms (480x320) ------------- ------------- Disp clock = 10.00 MHz (requested: 10.00) Lines = 1395 ms (320 lines of 480 pixels) Read check OK, line 293 Pixels = 3572 ms (480x320) Cls = 382 ms (480x320) ------------- ------------- Disp clock = 16.00 MHz (requested: 16.00) Lines = 1394 ms (320 lines of 480 pixels) Read check OK, line 300 Pixels = 2718 ms (480x320) Cls = 244 ms (480x320) ------------- ### MAX READ SPI CLOCK set to 16.00 MHz ### ------------- Disp clock = 26.67 MHz (requested: 30.00) Lines = 1393 ms (320 lines of 480 pixels) Read check Err, on line 232 at 17 (Read clock = 30.00 MHz) Pixels = 2131 ms (480x320) Cls = 152 ms (480x320) ------------- ------------- Disp clock = 40.00 MHz (requested: 40.00) Lines = 1392 ms (320 lines of 480 pixels) Read check OK, line 163 (Read clock = 16.00 MHz) Pixels = 1835 ms (480x320) Cls = 106 ms (480x320) ------------- Graphics demo started --------------------- DMA mode: OFF GRAYSCALE mode: OFF Clear screen time: 226 ms Display line time: 720 us JPG Decode time: 411 ms Decode JPG (file): 411 ms BMP Decode time: 768 ms DMA mode: ON GRAYSCALE mode: OFF Clear screen time: 106 ms Display line time: 341 us JPG Decode time: 211 ms Decode JPG (file): 211 ms BMP Decode time: 768 ms DMA mode: OFF GRAYSCALE mode: ON Clear screen time: 453 ms Display line time: 1586 us JPG Decode time: 742 ms Decode JPG (file): 742 ms BMP Decode time: 1103 ms DMA mode: ON GRAYSCALE mode: ON Clear screen time: 106 ms Display line time: 958 us JPG Decode time: 557 ms Decode JPG (file): 557 ms BMP Decode time: 1103 ms
I will check and will let you know if any issue.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: Bytespider and 4 guests
