About the CAN controller.
Beck-Sisyphus
Re: About the CAN controller.
Thank you Rudi for the explanation! I will test my board out and see the result.
Thanks iosixllc for the head up.
Beck
Beck
Hi guys...
Sorry for the late reply but im drowning in work.
Ill try my best to implement the change requests in the next 2 weeks.
Regards
Thomas
Regards
Thomas
my page: http://www.barth-dev.de/
added extended frame format, check https://github.com/ThomasBarth/ESP32-CAN-Driver
added RTR support: https://github.com/ThomasBarth/ESP32-CAN-Driver
The interface changed a little, the Frame Information record is now copied into the frame type.
This has the advantage that all the information like DLC or RTR can be copied in a single access, which boosts performance. Also this helps to keep the queues small.
Beck-Sisyphus
Hi Rudi and Thomas,
Error report: 'CLEAR_PERI_REG_MASK' and 'SET_PERI_REG_MASK' error
OS: MacOS;
toolchain: ESP-IDF;
Commit: lastest from github.
component.mk: empty
Makefile:
PROJECT_NAME := CAN_demo
include $(IDF_PATH)/make/project.mk
I got new error in calling 'CLEAR_PERI_REG_MASK' and 'SET_PERI_REG_MASK', and here is a part of it:
/Users/Beck/Developer/esp/esp-idf/components/esp32/include/esp_assert.h:23:13: error: static assertion failed: "(Cannot use READ_PERI_REG for DPORT registers use DPORT_READ_PERI_REG)"
_Static_assert(__builtin_choose_expr(__builtin_constant_p(CONDITION), (CONDITION), 1), #MSG); \
/Users/Beck/Developer/esp/esp-idf/components/soc/esp32/include/soc/soc.h:218:76: note: in definition of macro 'WRITE_PERI_REG'
(*((volatile uint32_t *)ETS_UNCACHED_ADDR(addr))) = (uint32_t)(val); \
/Users/Beck/Developer/esp/esp-idf/components/soc/esp32/include/soc/soc.h:138:38: note: in expansion of macro 'TRY_STATIC_ASSERT'
#define ASSERT_IF_DPORT_REG(_r, OP) TRY_STATIC_ASSERT(!IS_DPORT_REG(_r), (Cannot use OP for DPORT registers use DPORT_##OP));
/Users/Beck/Developer/esp/esp-idf/components/soc/esp32/include/soc/soc.h:211:13: note: in expansion of macro 'ASSERT_IF_DPORT_REG'
ASSERT_IF_DPORT_REG((addr), READ_PERI_REG); \
/Users/Beck/Developer/esp/esp-idf/components/soc/esp32/include/soc/soc.h:224:36: note: in expansion of macro 'READ_PERI_REG'
WRITE_PERI_REG((reg), (READ_PERI_REG(reg)&(~(mask)))); \
/Users/Beck/Developer/esp/can_bus_components/components/can/./CAN.c:185:5: note: in expansion of macro 'CLEAR_PERI_REG_MASK'
CLEAR_PERI_REG_MASK(DPORT_PERIP_RST_EN_REG, DPORT_CAN_RST);
May I got a hit how to resolve this?
OS: MacOS;
toolchain: ESP-IDF;
component.mk: empty
Makefile:
First of all thanks to everybody who contributed to the ESP32 CAN driver, especially to Thomas Barth. Thomas, I owe you a beer. (How about a Grohe Pilsener)
I am an hobby enthusiast to embedded systems and Android app programing. In embedded systems I started my "career" on Arduino AVR boards. My knowledge in C/Cpp and in electronics is limited and I have almost no knowlegde about compilers, makefiles, toolchains etc.
When the ESP8266 came out I learnd that the chip can also be programmed using the Arduino environment. With the ESP8266 I realized some nice projects in home automation.
I am also an motorcycle enthusiast and programmed a data recording (Android) app using a modified ELM327 Bluetooth adapter to tap the CAN bus of my motorcycle.
When I saw, that the ESP32 includes a CAN module I was thrilled, because now embedded system and motorcycle data recording meet.
But then I realized that even though there is support for the ESP32 in the Arduino environment there is no driver for the CAN module.
Lukily I found the CAN driver and the demo created by Thomas Barth. To use the driver in the Arduino environment I rearranged the folder structure a little bit, removed the "cfg" folder including CAN_config.c file and renamed CAN.c to CAN.cpp. It now looks like:
For testing I set up a CAN bus with an Arduino Uno + CAN module (ID 0x120), an Arduino Nano + CAN module (ID 0x120) and an ESP32ST development board. The bus runs with 500 kbps. I use a 3,3 Volt SN65HVD230 CAN Bus Transceiver. The Arduinos fire each a CAN frames with eight data about every 10 milliseconds. The ESP32ST development board fire every second a CAN frame
The Arduino ino file looks like:
The whole setup runs smooth over days. On the serial port of ESP32 the frames send by the Arduinos with a timestamp (in milliseconds) can be monitored.
Next step for me is to connect the ESP32ST development board to my motorcycle. The motorcycle fires about 800 frames/seconds with 8 bytes payload each. I plan to perform the test in "Silent mode" to not interfere with the motorcycle CAN traffic.
If someone is interested I will report about the result.
[folder] library
[folder] CAN_ESP32
[file] CAN.cpp
[file] CAN.h
[folder] incude
[file] CAN_config.h
[file] can_regdef.hThe Arduino ino file looks like:
#include "CAN.h"
CAN_device_t CAN_cfg = {
.speed=CAN_SPEED_500KBPS, // CAN Node baudrade
.tx_pin_id = GPIO_NUM_5, // CAN TX pin
.rx_pin_id = GPIO_NUM_4, // CAN RX pin
.rx_queue=NULL, // FreeRTOS queue for RX frames
CAN_frame_t frame;
CAN_frame_t __RX_frame;
long t_old;
void setup() {
Serial.begin(500000);
//create CAN RX Queue
CAN_cfg.rx_queue = xQueueCreate(10,sizeof(CAN_frame_t));
//start CAN Module
CAN_init();
void loop() {
if ((millis()-t_old)>1000){
t_old=millis();
frame.MsgID=0x3ff;
frame.DLC=8;
frame.data.u8[0]='C';
frame.data.u8[1]='A';
frame.data.u8[2]='N';
frame.data.u8[3]='E';
frame.data.u8[4]='S';
frame.data.u8[5]='P';
frame.data.u8[6]='3';
frame.data.u8[7]='2';
CAN_write_frame(&frame);
if(xQueueReceive(CAN_cfg.rx_queue,&__RX_frame, 3*portTICK_PERIOD_MS)==pdTRUE){
Serial.print(millis());
Serial.print("/");
Serial.print(String(__RX_frame.MsgID,HEX));
Serial.print((char)__RX_frame.data.u8[0]);
Serial.print((char)__RX_frame.data.u8[1]);
Serial.print((char)__RX_frame.data.u8[2]);
Serial.print((char)__RX_frame.data.u8[3]);
Serial.print((char)__RX_frame.data.u8[4]);
Serial.print((char)__RX_frame.data.u8[5]);
Serial.print((char)__RX_frame.data.u8[6]);
Serial.println((char)__RX_frame.data.u8[7]);
delay(0);
2073687/110CAN-NANO
2073690/120CAN-UNO
2073697/110CAN-NANO
2073700/120CAN-UNO
2073708/110CAN-NANO
2073711/120CAN-UNO
2073720/110CAN-NANO
2073723/120CAN-UNO
2073731/110CAN-NANO
2073734/120CAN-UNO
2073741/110CAN-NANO
2073744/120CAN-UNO
2073752/110CAN-NANO
2073755/120CAN-UNO
2073764/110CAN-NANO
2073767/120CAN-UNO
2073775/110CAN-NANO
2073778/120CAN-UNO
2073785/110CAN-NANO
The build issue with the CAN driver seems to have been introduced by: https://github.com/espressif/esp-idf/co ... 620f42173c
I posted a fix as a pull request to Thomas' git repo: https://github.com/ThomasBarth/ESP32-CAN-Driver/pull/7
Regards
Frieder
Regards
Frieder
Hi Rudi and Thomas,
hi
you can try to use this branch in the meantime
i think thomas is update very soon the repo too. it was a change ( named changed ) on espressif ESP-IDF.
btw, thomas add support for extended frames and other things, this is in the top named repo included, also the DPORT access change.
have a try and let me know
rudi
Users browsing this forum: Semrush [Bot] and 3 guests
