My company works on several ESP32 based projects and we noticed an issue when using the ESP IDF scripts/tools to flash and reset the development kits.
What is happening is that from time to time the device will not be reset when using a flash command and we cannot identify what could cause such issue.
For example on ESP32-S2 with ESP IDF v4.2.2 we use the following command to flash and reset dev kits:
python %IDF_PATH%\components\esptool_py\esptool\esptool.py -p COM8 -b 921600 --before default_reset --after hard_reset --chip esp32s2 write_flash --flash_mode dio --flash_size detect --flash_freq 80m application.binThe same issue can appear on a ESP32 WROVER dev kit with ESP IDF v3.3.4.
Since it is not consistent we do not know how we can reproduce and why it happens.
Is there any known issue that could cause this?
Regards,
Benjamin
