ESP32-C3-WROOM-02 minimum voltage
Since the flash on the wroom seems to be minimum 2.7v according to BOM, is it possible that the module could be used down to 2.7v instead of the stated 3.0v in the datasheet?
Re: ESP32-C3-WROOM-02 minimum voltage
EDIT: This text was incorrect. Please see my colleagues response below.
Please be noted that for ESP32-C3, min. voltage for all power domains is 3.0 V, so the lowest voltage is limited by ESP32-C3 not flash.
Thank you.Please be noted that for ESP32-C3, min. voltage for all power domains is 3.0 V, so the lowest voltage is limited by ESP32-C3 not flash.
Users browsing this forum: Google [Bot], Perplexity-User, PetalBot and 2 guests
