I have an issue getting WPS to work correctly on an ESP32-C3 demo board running ESP-IDF v4.3.2
I am using unmodified demo code (Examples/WiFi/WPS)
If I put the router into WPS, then start the demo it will connect to the router correctly.
If I start the demo, then put the router into WPS it will not connect and WPS will timeout.
At the end of the timeout, the demo restarts the WPS procedure again, and it then connects.
I don't believe this is correct behavior, as it shouldn't have to wait for the timeout before connecting.
I also don't think restarting the WPS connection after timeout is a good idea.
Does anyone else experience this? Or is there a setting that is missing
