In a peripheral registers section of a technical reference manual, what the meaning of "SS" and "WTC" access types?
Thanks,
Register "SS", "WTC" access types
Re: Register "SS", "WTC" access types
WTC is Write To Clear. SS, I don't know; do you have a particular bit where it appears? I'll see if we can do something about those abbreviations; you're not the only one having a hard time figuring out what everything stands for; it would be good to be able to hover over those things and get whatever it stands for.
Thanks for the reply.
You can find "SS" in such as ESP32C3 Technical Reference Manual, see attached image.
https://www.espressif.com/sites/default ... ual_en.pdf "SS" seems related to RAW register?
I also find "WT" access type and this seems related CLR register...?
Finally I found the answer in ESP32 technical reference manual.
Thanks,
Users browsing this forum: YisouSpider and 1 guest
