Reason and cause for RTCWDT_RTC_RESET on boot?
desp32fun
Postby desp32fun » Sun Jan 23, 2022 1:27 pm
Hi all,
what is the intended reason and cause for RTCWDT_RTC_RESET on boot?
I had some WROVER-E Modules dying in the field with an RTCWDT_RTC_RESET boot loop after weeks of proper operation.
Sadly, the module does not recover by re-flashing the module like in the first thread below.
My hope would be something buried in the bootloader which could be fixed or circumvented in software?
RTCWDT_RTC_RESET pops up in this thread about WROVER-E: "Hardware Flash Corruption Issue"
https://www.esp32.com/viewtopic.php?f=12&t=25667#p90766
RTCWDT_RTC_RESET pops up in a thread with a different flash-chip: "ESP32-D0WD Design Issue."
viewtopic.php?f=2&t=22813
and probably more. Sadly, the forum search as always only returns an empty white page, so I can't search properly
for more hints.
What I see:
ets Jul 29 2019 12:21:46
rst:0x10 (RTCWDT_RTC_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:380
ho 0 tail 12 room 4
load:0x0780000,len:3378177
load:0x07800000,len:3378177
ho 0 tail 12 room 4
Any hints there?
Best regards
WiFive
Re: Reason and cause for RTCWDT_RTC_RESET on boot?
Postby WiFive » Sun Jan 23, 2022 2:12 pm
Similar to those other issues, there is a problem loading the second stage bootloader from flash. boot:0x33 shows 1.8v flash mode which is not correct for wrover-e unless you override it in efuse.
viewtopic.php?f=12&t=22938
desp32fun
Postby desp32fun » Sun Jan 23, 2022 2:29 pm
I see. Now there's a problem. I've pinned SDIO voltage to 3V3 by burning the appropriate fuse,
and as it seems, the bootloader does not pick that setting up, setting the flash to 1V8?
Are we talking about these fuses?
espefuse.py --port /dev/ttyUSB0 summary
XPD_SDIO_FORCE (BLOCK0):                 Ignore MTDI pin (GPIO12) for VDD_SDIO on reset     = True R/W (0b1)
XPD_SDIO_REG (BLOCK0):                   If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset    = True R/W (0b1)
XPD_SDIO_TIEH (BLOCK0):                  If XPD_SDIO_FORCE & XPD_SDIO_REG                   = 3.3V R/W (0b1)
... lots of stuff ...
Flash voltage (VDD_SDIO) set to 3.3V by efuse.
WiFive
Postby WiFive » Sun Jan 23, 2022 7:59 pm
You will not see a change to the boot:0x33 value because it represents strapping pins only
desp32fun
Postby desp32fun » Mon Jan 24, 2022 8:34 am
So do I understand this correctly?
When some of our WROVER-E boards boot, they provide the flash with 1.8V instead of 3.3V?
And they show in the boot loader that GPIO12 is reading HIGH on startup? (boot:0x33)
And this happens although we've set the Fuses that force VDD_SDIO to 3.3V?
WiFive
Postby WiFive » Mon Jan 24, 2022 1:58 pm
No, if you set the efuse to force 3.3v you should get 3.3v even with gpio12 high. So that is not the problem then.
