What is the difference between ESP32-wroom-32 and ESP- Wroom-32?
alsiavash1633
Postby alsiavash1633 » Sat Feb 12, 2022 10:46 am
What is the difference between ESP32-wroom-32 and ESP- Wroom-32? Can they be used interchangeably?
alsiavash1633
Re: What is the difference between ESP32-wroom-32 and ESP- Wroom-32?
Postby alsiavash1633 » Sun Feb 13, 2022 6:03 am
Some chips are ESP32-wroom-32 and some are ESP-Wroom-32. What is the difference between them? please reply .
Postby Sprite » Sun Feb 13, 2022 7:31 am
Do you have links to the two? Those things aren't chips but modules btw.
Postby Sprite » Mon Feb 14, 2022 1:33 am
Those are both different revisions of the same module; aside from potentially some RF changes there's not much difference between them. Be advised that you're likely to get a newer version of the module, however, as both modules were deprecated a fairly long time ago. As far as programming them goes, they're still exchangable (unless you use the GPIOs that are occupied by flash; they are NC in newer versions)
Users browsing this forum: No registered users and 9 guests
