Setting up Development Toolchain for ESP32
f.h-f.s.
Re: Setting up Development Toolchain for ESP32
Postby f.h-f.s. » Wed May 24, 2017 9:50 am
that no rule to make target, sounds to me like IDF_PATH is not set.
wind_energy
Postby wind_energy » Wed May 24, 2017 1:25 pm
Ok, but how to set the IDF_PATH?
Postby rudi ;-) » Wed May 24, 2017 1:32 pm
where you set it?
$ echo $IDF_PATH
how is the echo out print?
does it show the idf_path ?
wind_energy
Postby wind_energy » Wed May 24, 2017 5:58 pm
hi Rudi :)
pbl@pbl-Komputer MINGW64 ~
$ echo $IDF_PATH
C:/msys32/home/pawel/esp/esp-idf
C:\msys32\home\pawel\esp\esp-idf - is empty at the moment
Regards,
Pawel
wind_energy
Postby wind_energy » Wed May 24, 2017 6:00 pm
hi Rudi :)
$ echo $IDF_PATH
Regards,
Pawel
Postby rudi ;-) » Wed May 24, 2017 8:24 pm
hi Rudi :)
$ echo $IDF_PATH
Regards,
Pawel
from your first post:
1. I have downloaded the esp32_win32_msys2_environment_and_toolchain-20170330,
2. then made git clone --recursive https://github.com/espressif/esp-idf.git in under a directory C:\ESP\esp-idf
3. Downloaded the template into directory myapp2 git clone https://github.com/espressif/esp-idf-template.git myapp2
4. Exported export IDF_PATH="C:\ESP\esp-idf"
5. Then hit the make command to compile the project. make
you must get the exported path "c:/ESP/esp-idf"
from your next post you have done the recursive download right way cause your IDF_PATH folder does have the esp-idf
so then you started again the install after clean and delete all.
and then there must be done a wrong step - cause your IDF_PATH folder is now empty
and shows to the "C:/msys32/home/pawel/esp/esp-idf"
proposal in this moment:
look at c:\ESP\esp-idf
is this folder now empty or does it have the esp-idf ?
if this folder have the esp-idf
then in clean / delete doings there was a step wrong too
the question is:
how you have done the rekursive download
cause usually the rekursive download must "download to a folder...."
your post shows:
this step comes from here
cd ~/esp
so you will find the esp-idf then here:
~/esp/esp-idf
and thats the echo output what you get
means, that is your user home
user: pbl
home is usually : /home/pbl
but you have an other user here :)
user is: pawel
$ echo $IDF_PATH
and the question is: how is that possible?
it looks,
- you have installed msys32 environment with user: pbl
- you try to install esp-idf to the home of user: pawel
look in the folder structure
c:/msys32/home
there are two users show then
pbl
pawel
and there was a mistake in install then ..
cause the esp-idf shown from your post
shows, that the esp-idf is not in the home installed
but under c:/esp...
short and dirty:
a)
check is your python ok
type
$ python -V
what is your output?
b)
if you have installed msys32 and toolchain and the things are under c:/msys32
use the msys32 shell command
now check for the runing "make" you have installed:
type
make -v
what is the output?
c)
if your output is likewise:
example:
$ python -V
Python 2.7.11
python is instaled and in the path entried.
$ make -v
GNU Make 4.2.1
Gebaut für i686-pc-msys
Copyright (C) 1988-2016 Free Software Foundation, Inc.
Lizenz GPLv3+: GNU GPL Version 3 oder später <http://gnu.org/licenses/gpl.html>
Dies ist freie Software: Sie können sie nach Belieben ändern und weiter verteilen.
Soweit es die Gesetze erlauben gibt es KEINE GARANTIE.
or likewise and you have the esp-idf in c:\esp\esp-idf
then export the path to the installed esp-idf like this
usually like the install readme is normal:
export IDF_PATH="C:/msys32/home/Krzysztof/esp/esp-idf"
then the esp-idf must be in your home of msys32 shell
see detailed to the command, the example shows the user "Krzysztof"
your user name is different, use the right you want use
AND!
if you work with this -
be sure you are login in windows with this user :)
AND if you set to different folder outside the msys32 shell home ( c:/msys32/home)
example c:/ESP/esp-idf
then you must export the idf like this
export IDF_PATH="C:/ESP/esp-idf"
now usually the "make" find the the esp-idf makefile
before next steps give feedback, does this make now find the makefile?
next step then are example project / Hello world ...
GeorgeIoak
Postby GeorgeIoak » Wed May 24, 2017 8:51 pm
From your last post you showed that you issued make in the getting started directory but you need to go down 1 more level into the hello world directory and then issue make
wind_energy
Postby wind_energy » Thu May 25, 2017 4:55 am
Rudi,
CODE: SELECT ALL
pbl
pawel
How can I fix it?
a)
type
CODE: SELECT ALL
$ python -V
Answare:
$ python -V
-bash: python:  No command found
Many thanx !!
Pawel
Users browsing this forum: Bing [Bot], Qwantbot, Semrush [Bot], YisouSpider and 2 guests
