ESP32-S3 maximum theoretical PSRAM speed
accessays
Postby accessays » Wed Feb 23, 2022 3:09 am
I am working on a project that requires the use of PSRAM and seems to be bottlenecked by its speed. I was wondering what the theoretical maximum PSRAM speed is? I currently use an N8R2 module, QSPI @120MHz mode. I've found out that NxR8 modules have Octal SPI, as well as are DTR instead of STR. But are those modules able to run @120MHz? In idf.py menuconfig if I select Octal SPI for PSRAM, the maximum selectable frequency becomes 80 MHz, which these modules would be (only) ~2.6 times faster than N8R2.
As I understand it, CPU frequency needs to evenly divide PSRAM frequency. Does that mean there could be a module using OPI PSRAM @160MHz, or possibly @240MHz?
Thanks in advance.
Users browsing this forum: Bing [Bot], Bytespider, Google [Bot], Qwantbot and 0 guests
