是的,用 omnipeek 抓。
I (30) boot: ESP-IDF v4.3.2-dirty 2nd stage bootloader
I (30) boot: compile time 17:21:58
I (30) boot: chip revision: 3
I (32) boot.esp32c3: SPI Speed : 80MHz
I (37) boot.esp32c3: SPI Mode : DIO
I (42) boot.esp32c3: SPI Flash Size : 4MB
I (47) boot: Enabling RNG early entropy source...
I (52) boot: Partition Table:
I (56) boot: ## Label Usage Type ST Offset Length
I (63) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (70) boot: 1 otadata OTA data 01 00 0000d000 00002000
I (78) boot: 2 phy_init RF data 01 01 0000f000 00001000
I (85) boot: 3 ota_0 OTA app 00 10 00010000 00180000
I (93) boot: 4 ota_1 OTA app 00 11 00190000 00180000
I (100) boot: 5 settings unknown 40 00 00310000 00001000
I (108) boot: 6 file unknown 40 00 00311000 000ef000
I (115) boot: End of partition table
I (120) esp_image: segment 0: paddr=00010020 vaddr=3c0e0020 size=2c920h (182560) map
I (155) esp_image: segment 1: paddr=0003c948 vaddr=3fc8fe00 size=036d0h ( 14032) load
I (158) esp_image: segment 2: paddr=00040020 vaddr=42000020 size=da408h (893960) map
I (295) esp_image: segment 3: paddr=0011a430 vaddr=3fc934d0 size=004f8h ( 1272) load
I (296) esp_image: segment 4: paddr=0011a930 vaddr=40380000 size=0fc48h ( 64584) load
I (313) esp_image: segment 5: paddr=0012a580 vaddr=50000000 size=00010h ( 16) load
I (318) boot: Loaded app from partition at offset 0x10000
I (318) boot: Disabling RNG early entropy source...
I (333) cpu_start: Pro cpu up.
I (345) cpu_start: Pro cpu start user code
I (345) cpu_start: cpu freq: 160000000
I (346) cpu_start: Application information:
I (348) cpu_start: Project name: blufi_demo
I (353) cpu_start: App version: 1
I (358) cpu_start: Compile time: Mar 3 2022 09:13:30
I (364) cpu_start: ELF file SHA256: 6f04524babec802f...
I (370) cpu_start: ESP-IDF: v4.3.2-dirty
I (375) heap_init: Initializing. RAM available for dynamic allocation:
I (383) heap_init: At 3FC9B820 len 000247E0 (145 KiB): DRAM
I (389) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM
I (396) heap_init: At 50000010 len 00001FF0 (7 KiB): RTCRAM
I (402) spi_flash: detected chip: mxic
I (406) spi_flash: flash io: dio
I (411) sleep: Configure to isolate all GPIO pins in sleep state
I (417) sleep: Enable automatic switching of GPIO sleep configuration
I (424) cpu_start: Starting scheduler.
I (433) coexist: coexist rom version 9387209
I (433) pp: pp rom version: 9387209
I (433) net80211: net80211 rom version: 9387209
I (453) wifi:wifi driver task: 3fca4630, prio:23, stack:6656, core=0
I (453) system_api: Base MAC address is not set
I (453) system_api: read default base MAC address from EFUSE
I (463) wifi:wifi firmware version: eb52264
I (463) wifi:wifi certification version: v7.0
I (463) wifi:config NVS flash: enabled
I (473) wifi:config nano formating: disabled
I (473) wifi:Init data frame dynamic rx buffer num: 32
I (483) wifi:Init management frame dynamic rx buffer num: 32
I (483) wifi:Init management short buffer num: 32
I (493) wifi:Init dynamic tx buffer num: 32
I (493) wifi:Init static tx FG buffer num: 2
I (493) wifi:Init static rx buffer size: 1600
I (503) wifi:Init static rx buffer num: 10
I (503) wifi:Init dynamic rx buffer num: 32
I (513) wifi_init: rx ba win: 6
I (513) wifi_init: tcpip mbox: 32
I (513) wifi_init: udp mbox: 6
I (523) wifi_init: tcp mbox: 6
I (523) wifi_init: tcp tx win: 5744
I (533) wifi_init: tcp rx win: 5744
I (533) wifi_init: tcp mss: 1440
I (533) wifi_init: WiFi IRAM OP enabled
I (543) wifi_init: WiFi RX IRAM OP enabled
I (543) phy_init: phy_version 905,7b93cd2,Oct 25 2021,15:05:11
I (593) wifi:set rx active PTI: 0, rx ack PTI: 12, and default PTI: 1
I (593) wifi:mode : sta (60:55:f9:72:fc:94)
I (593) wifi:enable tsf
I (593) BLUFI_EXAMPLE: WIFI_EVENT_STA_START
W (603) BTDM_INIT: esp_bt_controller_mem_release not implemented, return OK
I (603) wifi:new:<1,1>, old:<1,0>, ap:<255,255>, sta:<1,1>, prof:1
I (613) wifi:state: init -> auth (b0)
I (613) BTDM_INIT: BT controller compile version [3e61eea]
I (623) coexist: coexist rom version 9387209
I (633) BTDM_INIT: Bluetooth MAC: 60:55:f9:72:fc:95
I (633) wifi:state: auth -> assoc (0)
I (653) BLUFI_EXAMPLE: BD ADDR: 60:55:f9:72:fc:95
I (653) BLUFI_EXAMPLE: BLUFI init finish
W (653) BT_BTM: BTM_BleWriteAdvData, Partial data write into ADV
I (663) BLUFI_EXAMPLE: BLUFI VERSION 0102
I (663) Protocol: 0x3fcb35b8 fa 00 00 00 00 02 00 11 8c ff 05 00 |............|
I (673) : start tcp_client_task
I (673) WIFI: wait to get IP
I (673) : start tcp_client_recv_task
I (683) gpio: GPIO[4]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (693) gpio: GPIO[5]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (693) wifi:state: assoc -> run (10)
I (703) : start state_led_task
W (703) wifi:<ba-add>idx:0 (ifx:0, 58:41:20:09:d9:62), tid:5, ssn:0, winSize:64
I (713) : start get_RSSI_task
I (713) BLUFI_EXAMPLE: set rssi threshold
I (813) wifi:connected with TP-LINK_JSB_WZ, aid = 3, channel 1, 40U, bssid = 58:41:20:09:d9:62
I (813) wifi:security: WPA2-PSK, phy: bgn, rssi: -31
I (813) wifi:pm start, type: 1
I (813) wifi:set rx beacon pti, rx_bcn_pti: 14, bcn_timeout: 14, mt_pti: 25000, mt_time: 10000
I (823) BLUFI_EXAMPLE: WIFI_EVENT_STA_CONNECTED
I (883) wifi:BcnInt:102400, DTIM:1
I (883) BLUFI_EXAMPLE: rssi:-31
I (883) Protocol: 0x3fcbc5b4 fa 00 00 00 00 02 00 11 8c e7 04 1f |............|
I (883) BLUFI_EXAMPLE: mac:MAC6055f972fc94
I (1673) WIFI: wait to get IP
I (2673) WIFI: wait to get IP
I (3673) WIFI: wait to get IP
I (4673) WIFI: wait to get IP
I (5673) WIFI: wait to get IP
I (5723) BLUFI_EXAMPLE: set rssi threshold
I (6623) BLUFI_EXAMPLE: rssi:-31
I (6623) Protocol: 0x3fcbc5b4 fa 00 00 00 00 02 00 11 8c e7 04 1f |............|
I (6623) BLUFI_EXAMPLE: mac:MAC6055f972fc94
I (6673) WIFI: wait to get IP
I (7673) WIFI: wait to get IP
I (8673) WIFI: wait to get IP
I (9673) WIFI: wait to get IP
I (10673) WIFI: wait to get IP
I (10723) BLUFI_EXAMPLE: set rssi threshold
I (11123) BLUFI_EXAMPLE: rssi:-31
I (11123) Protocol: 0x3fcbc5b4 fa 00 00 00 00 02 00 11 8c e7 04 1f |............|
I (11123) BLUFI_EXAMPLE: mac:MAC6055f972fc94
I (11673) WIFI: wait to get IP
I (12673) WIFI: wait to get IP
I (13673) WIFI: wait to get IP
I (14673) WIFI: wait to get IP
I (15673) WIFI: wait to get IP
I (15723) BLUFI_EXAMPLE: set rssi threshold
I (16673) WIFI: wait to get IP
I (16753) BLUFI_EXAMPLE: rssi:-31
I (16753) Protocol: 0x3fcbc5b4 fa 00 00 00 00 02 00 11 8c e7 04 1f |............|
I (16753) BLUFI_EXAMPLE: mac:MAC6055f972fc94
I (17673) WIFI: wait to get IP
I (18673) WIFI: wait to get IP
